Question about Lexmark Wheelwriter 6 Series II Typewriter
WHEELRITER 6 LOST MEMORY.
WE HAVE HAD OUR WHEELRITER 6 FOR OVER 20 YEARS. THE MEMORY APPEARS TO BE GONE. WE PUT NEW BATTERIES IN, BUT WE HAVE LOST ALL IN THE DIRECTORY. WHEN WE HIT DIR. PRINT IT ONLY PRINTS 13500 SECRETARY CAN'T REMEMBER HOW TO REPROGRAM AND CAN'T OUR FIND MANUAL. CAN YOU ASSIST?
  • Lexmark Master
  • 3,594 Answers
When it turns on do the lights blink and go out on the first key touched? If so the battery hilder is probably corroded. Clean the contacts with sand paper. When this is solved you can start storing again. The data is lost and can't be retrieved.
DickyO
Posted on Feb 23, 2008
Xd card wont read in laptop
look for a new drive letter on the laptop. Check the directory for the new drive letter for the pictures. If no new drive letter appears, try putting the memory card in the slot several times to make sure there is a good connection between the card and the computer.
Jul 16, 2014 | Olympus Cameras
Whats wrong when the computer as ys check your charging station
Does the radio turn on when you turn ignition. If not then the Battery
has bad cell. Replace battery. Battery's in Olds Aurora 98 typically
get a very long life. 6 years . After 6 I recommend replacing battery
If your car turns what does your battery read. If it's reading only 12 V
with eng. going, your alternator has gone out. If battery is new then you'll need to find another reason your battery is draining charge.
Jul 15, 2014 | 1998 Oldsmobile Aurora
2000 neon new battery starter clicking
could be a number of things. like the regulator for the altenator sticking. the memory on aftermarket radios could do it. Also amps if you have one.
Dec 31, 2011 | 2000 Dodge Neon
I have a 1991 dodeg dakota sport (v-6) and in the past 3 months i have "gone through 3 batteries and 2 alternators. i pulled trouble codes and the same code comes up, code 12 ( stand by memory power...
CODE 12 STAND BY MEMORY POWER LOST.WHAT IT SAYING ECM LOSING MEMORY BECAUSE LACK OF POWER.POSSIBLE CAUSE TO YOUR PROBLEM COULD BE OLD WORN OUT BATTERY CABLES CAUSING POOR GROUND AND HIGH RESISTANCE IN CHARGING CIRCUIT.YOU COULD HAVE WRONG AMP ALTERNATOR AND BATTERY WRONG COLD CRANKING AMPS.MAKE SURE ALTERNATOR BELT TIGHT AND CHECK ALTERNATOR BATTERY FEED WIRE AND ALTERNATOR FIELD WIRES FOR DAMAGE OR LOOSE CONNECTIONS.CHECK ALTERNATOR FUSE. WITH ENGINE RUNNING ALTERNATOR OUT PUT SHOULD BE 13.5 TO 14.5 VOLTS IF NOT ALTERNATOR NOT CHARGING.
Nov 18, 2010 | Dodge Dakota Cars & Trucks
My 14.4 dewalt drill is not workind at all. I used only 1 year and I would like to find a shop to repair it. I live in Shepherds Bush W12
Go on the dewaltervicenet.com website and click on service support and then click on service center locator. You can then enter your location and it will tell you the closest repair center.
Sep 09, 2009 | Dewalt Accessories No.DW4808B25 6" 14TPI...
My (3 year old)Sony Ericsson W600i just lost all of my photos, videos and music. When I try to hook it up to my computer, there is nothing in any the files. However, the phone says that I only have 55mb of...
I think you had dropped the phone. Dont worry...The data will be there in your phone. Connect your phone to a PC.Browse all the directories(Not only just the directory which corresponds to the locations where the files where present).Sometimes you can see some newly created directories also. DOnt leave any directories. You will find it.
Aug 24, 2009 | Cell Phones
GPS has lost it's memory, adress book and recent trips
if the gps relies on the main battery for memory,that is why it is gone.the battery died
they should have a separate back up like a computer has a battery inside to retain the bios information and clock settings.
you should have a small secondary battery like a motorcycle battery,in parallel with the main battery isolated by a diode.
Apr 26, 2009 | 2004 Jeep Grand Cherokee
Lexmark Wheelwriter 6 Series II Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
