Question about Symphonic SC1302 Combo
T.v keeps turning off
I have a symphonic model sc319b it stays on for 5 seconds then shuts off also i have bought 5 remotes and cant get them to work please help
  • Anonymous Apr 29, 2008
    i have the same problem please let me know if you have a solution
    tfvaldes18@hotmail.com
    Genius:
  • Symphonic Master
  • 1,550 Answers
Change the belt of the vcr motor charge is all the problem.Good luck.
Posted on May 06, 2008
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
Jun 01, 2015 | Sherwood RX-4105 2-CHANNEL...
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
How do i program a rcr3273n rca remote to a symphonic
Hello
You just check with these codes
10180, 10171
30675, 30821, 31268
Manually turn on the device you
want to control.
Press and hold the device key you want to program. While
you're holding down the device key, use your other hand
to press and hold the remote's ON•OFF key at the same
time
Wait until the ON•OFF key comes on and stays on. Then
release both keys
Point the remote directly at the front panel of the device you
want to control. Press ON•OFF on the remote and wait 2
seconds. The remote is testing a single code for your device
Did your device turn off?
YES: Press the STOP key to store
the code. You're done! You've
programmed this device key.
NO: Press ON•OFF again. The
remote tests the next code for
your device.
Keep pressing ON•OFF every 2
seconds until your device turns back
on. When it does, press STOP
TIP: Because there are so many codes, you may have to press
the ON•OFF key many times-possibly hundreds of times.
Ok
Nov 25, 2010 | Symphonic ST420FF 20" TV
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
No Picture or Sound
I dont think it's worth getting a repair man to come fix a Symphonic TV... honestly, they are problem prone... and It would cost much less to just buy a whole new one. I have a symphonic tv with no remote, and now, I cant switch into game mode! It's like they designed their tv's to be crappy!
Jun 07, 2008 | Symphonic ST419E TV
Symphonic WF-719 19 in. TV/VCR/DVD Combo turns on and automatically shuts off I cant get it to stay on
It is likely that your infrared LED, under the VCR mechanism, might be dirty or failing.
Mar 17, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
8 month old Symphonic 20 inch lcd tv turns off itself every 3-5 seconds
these sets that shut down or turn themselves off after a few seconds usally have a bad backlite board in them. look closely at the screen and see if one section looks darker than the rest of the screen (top middle or bottom - top seems most common in my cases). some times if you put the tv on an unused input you can see the variation of light level on the screen, but don't get confussed by looking at the screen from too great of an angle. thanks ......techman 580-243-8025
Oct 27, 2007 | Televison & Video
Game Mode
I have the Xbox 360 remote... It works! ^_^ its $19.99 at best buy. When you programming it just hold down the TV and ok button. The number lights are going to stay on... put in 0445 the push the channel button up and down the TV will turn turn off/on. Then push the input button and you’re done. Hope this help.
Aug 29, 2007 | Symphonic ST419E TV
Symphonic SC1302 Combo Logo
192 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
