Question about Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Hi, a couple months ago the diplay would try to come on, the go black and make a poping noise. Sometimes I'd see some bright static lines and the power button would go orange. It sat because I was so disgusted with gateway and a diplay that lasted less than 2 years and they wouldn't offer any solutions, help or be anything but rude. Anyways, fired it up yesterday and it did the same thing untill I moved it around and then it worked untill now. Now it flashes on for a couple of secs with slight buzing noise, then screen goes black but power button stays blue. Power supply? I feel I can install whatever needed if you can also tell me where to get parts?
  • 1 more comment
  • tnt61 Mar 17, 2008
    I'm having the same problem...how do you run the factory reset?
  • Anonymous May 21, 2008
    Yup. My problem exactly. I've pulled the whole thing apart, and it seems like the high pitched buzzing sound is coming from the chip in the LCD panel itself.
    You said it for me, I am having the same problem and when called to Gateway they are firm that this is outta warranty so I said okay, but this seems to be a common problem, sorry but since you are out of warranty nothing can be done, can't even tell me how many of the same problems occur, Gateway is a sad sad company and sucks that they already got my money the first time, just spread the word this company does not stick behind its CRAPPY PRODUCT
Try running the factory reset on it.
Posted on Mar 13, 2008
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
I got a Gateway LCD 900G monitor, it keeps flickering and making hissing noises, what can i do?
Flickering could be a loose power connection but the hissing is indicative of a potential short. for your own safety, I'd get this to a TV type repairman asap.
Dec 25, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Bright blue patch in center of screen.
The optical block is going bad. Contact Sony support and have your model and serial numbers handy. Sony sometimes warranties these even after the 1yr factory warranty.
May 16, 2009 | Sony KDF-42WE655 Television
No power/dead
try to turn it on the power switch on monitor.....and make sure all connection are ok
Mar 06, 2009 | BenQ FP731 - 17" LCD Monitor
Menu keeps poping up & won't turn off
have you found a solution to this problem? i have the very same problem. i have taken apart the back of the monitor and found that if i take the small circuit board that is plugged into the power switch it goes away leading me to beleive that it is this small board but i do not know where to get it at. the number on the board is ar577 vk-583 rev:1. any help would be greatly appreciated. my email address is sachckc@gmail.com
Oct 22, 2008 | Acer AL1914 19" LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 power issue
I'm in the middle of moving so all my stuff is boxed up at the moment. If you want to send me your bad one, I can repair it for you.
Let me know.
Thanks.
Jul 30, 2008 | Computers & Internet
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Taking photos or video works sometimes
Hi, I think this is problem due to LCD Diplay. Sangita
Jul 23, 2007 | Canon PowerShot SD1000 Digital Camera
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
318 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
