Question about Braun Tassimo Espresso Machine/Coffee Maker
Tassimo one cup brewer
Coffee grinds are coming out from the T disc into the coffee I have only had this machine about a month, whats the problem here? Very unhappy spent good money for a broken product!!
  • Donkey man Mar 08, 2008
    No, I have already tried this, you took way too long to get back to me about the problem!
Hey at least you got a response. Btw, I answered it the same day I joined, Donkey - isn't that some type of ass?
Posted on Mar 09, 2008
Try cleaning the peircing mechanism (and around it) and making sure it is sitting snug. Sometimes mine comes off when I lift the lid to add a t-disc and this can cause some problems including grinds in the cup.
You may need to get a new peircing mechanism from Braun - if you've only had it for a month they should replace it.
Posted on Mar 05, 2008
Bosch tassimo coffee maker What is the yellow disc for where you place the coffee pod? Also what is the digital piece on the lid for? If for size of coffee cup fill , how do you adjust it?????
Hi The yellow disk is used when cleaning the coffee machine and the size for cups is usually on the tassimo pack at the back.
The "digital piece" is a bar code for the discs.Hope that helps? ps,
Go to Tassimo site for info
Feb 05, 2017 | Bosch Coffee Makers & Espresso Machines
How do I replace the service t disc for my mother-in-laws Bosch Tassimo T 20 Coffee Maker?
Ask your doctor to write you a prescription for one. Be sure to tell him what color you want.
Sep 09, 2016 | Bosch Tassimo T20 Single Serve Brewer,...
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
In the last couple of days our Keurig has been giving us lots of grinds. One entire cup was fllled with them while others have them floating. We use the K-cups from Keurig shipped to us. The coffee...
Hi,The bottom needle is plugged so the coffee is running back out over the top instead of going through the bottom needle...use a paper clip to open it up...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 06, 2011 | Keurig Elite B40 Coffee Maker
When my coffee starts to brew, the coffee (water) does not come down in a nice single stream. It is all spread out (kind of like water rolling off an umbrella) and some of it misses the cup. Also, alot of...
Sorry to read about your issue.
in addition to below take a pin and clean the little tube
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Keurig B60 Coffee Maker
Coffee maker is making very mild coffee. Looks more like tea. ANything that can be done?
You may need to add more grounds. We use 1/2 cup coffee grounds for our 10-cup machine, and it comes out perfect every time. If you prefer to grind your own beans, use 1/2 cup of beans, then grind.
Nov 29, 2010 | Bunn 10 Cup Home Coffee Brewer
PROBLEMS WITH THE BRAUN TASSIMO MACHINE AND T-DISCS
Drop kick the damn thing in the ocean! This machine is crazy! It spits boiling hot water and coffee grinds at you...
Feb 14, 2010 | Braun Tassimo Espresso Machine/Coffee...
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
183 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
