Question about Fellowes DM15C Shredder
Shredder problem paper will not feed into shredder
  • Anonymous Mar 17, 2014
    feeding wheels will not turn
My staples spl-1506X turns itself off and on in auto mode
Posted on Mar 14, 2008
    Scholar:
  • 102 Answers
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Posted on Feb 23, 2008
SOURCE: Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Posted on Oct 30, 2007
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
checkitright
  • 1362 Answers
SOURCE: Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Posted on Sep 05, 2008
SOURCE: NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Posted on Mar 22, 2009
  • 133 Answers
SOURCE: Paper no longer feeds in. Motor works.
Please check the sensor is on or off.
if paper is feeding completely then it means you need to buy a new one.
Posted on May 23, 2009
Why paper won't feed when shredder turns?
This may seem to simple but.......sometimes when you put too much oil into the blades through the top portion, the paper get drenched with oil and will not feed in. Plz try a few sheets or a thicker paper to push through. It may just be that simple. Good luck.
Plz N' Thnx, Bogie
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
May 22, 2009 | Royal 160MX Shredder
Sep 05, 2008 | Fellowes PS60C-2 Shredder
Shredder
If your unit has a mechanical paper feed sensor located in the center of the paper feed area there may be paper behind it causing switch not to activate. If it is an electronic sensor you probally have a burned out sensor, switch or a bad pc board. You will need to contact manufacturer for info on part replacement.
Mar 13, 2008 | Achiever CCS5000 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Fellowes paper shredder
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Fellowes DM15C Shredder Logo
765 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
