Drain Pump Filter Leaks on LG TROMM WM2277HW. Has a drain hose and a drain pump filter accessing from the front bottom left. Ever since I first took the filter off to clean it has been dripping constantly. What should I do? Another washer from somewhere?
  • Washington21 Dec 05, 2008
    Everytime I wash a load of clothes, my machine leaks water, I drain everyday an dif I wash more than 2 loads it still leaks. What can I do to stop this problem? I really need help ! I have only had m machine for 1 year and 2 months.
  • Anonymous Mar 30, 2014
    Is there a filter to clean or replace in lg tromm wm2277hw
I had to remove the two little plastic tabs that prevent you from tightening the filter plud too tight. Grind these two tabs off and you will find youare able to tighten the pluf just a bit more and it will no longer leak.
Posted on Feb 02, 2009
  • Washing Mach... Master
  • 2,651 Answers
Remove cover again , spend a few min cleaning the threads off, probly got some grit & dirt on them after water rushed out, dry them and a small film of vasiline over the o-ring wouldnt hurt nothing
Posted on Feb 23, 2008
Lg tromm front loader will tumble but wont spin
Open the access door at the bottom left corner of your washer. Use the small hose there to drain the remaining water from the machine. Un-screw the big knob next to it and pull out the attached filter. Clean out the filter and re-install. If the filter was clear, replace drain pump motor.
Mar 15, 2011 | LG WM2277H Front Load Washer
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Jan 10, 2011 | LG WM3431H Washer and Dryer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
How to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | LG WM2688HWM TROMM SteamWasher
Lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Tromm LG Washer
Santa says that "OF" code is really a "DF" (drain fault) which means check the filter (behind the access door at the lower left on front of the machine). There is a small drain hose next to it which should allow you to drain out the remaining water in the machine before you remove the filter. If the filter is clear, it is possible that the impeller on the pump motor is off, which requires a new pump motor. (if you push the impeller back on, it will only come off again) Santa would like a "fix ya" rating this year. thanks.
Sep 18, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm front loader OE
All of the ways to solve this problem are right on--take the filter out (in front on the bottom left when facing the machine). Before you do, take time to drain out the water with the hose below. Once drained open the filter and clean out. Try on speed wash with no spin. Nine minutes in you will know if the drain works. If not, turn on side and remove the washer pump. To do this, remove the hoses first starting with clamps. Then remove the three screws in front where the filter is. It easily comes out. The top pump is the drain pump. First mark the wires--blue is positive and black is negative. Remove the pump and clean out.The pump comes out of the casing. Try removing this and cleaning. If you have a power source, test the pump. If works, put back and start in fast cycle with no spin. If not, then you have to replace the drain pump. You will not find anyone in town the has the pump unless you live in New York or Dallas Texas. To get the pump at a reasonable price and expedited call and order through Sears at 18004881222. These guys are good and well get it to you as promised. The entire job once recieved the pump took about 30 minutes. Also, saved about $100 in labor. Good luck and hope this helps...
Aug 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
2,740 people viewed this question
Top Washing Machines Experts
