Question about Yamata FY920
No action every time i press the motor nothing happens...and i cant turn the wheel on the side either....the needles not moving and neither is the feed dog
  • Angey Feb 23, 2008
    thx much
    Problem Solver:
  • 14 Answers
Remove the bobbin, bobbin case as well as the shuttle hook. There are black pins/holders that hold the shuttle hook. After you remove these 3 components, make sure there are no thread stuck in between the 2 hook pieces as well as the bobbin shaft. Most of them time, there are either fabric or thread stuck. If not, make sure the needle is not hitting the feed dog or the hook.
Posted on Jul 08, 2008
  • 27 Answers
Sound like there is a thread jam somewhere. Check the bobbincase and hook assembly.
Posted on Feb 23, 2008
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand weel...
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
Nov 10, 2013 | Singer Inspiration 4206
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
How do I wind the bobbin on the Baby Lock Bl9?
will the bobbin winder spindel not move to the right at all?
Apr 02, 2012 | Baby Lock Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Arm wont move and needle wont go up and down any more in the middle of sewing, I was in the middle of sewing and all the sudden it froze up. It wont move any more and when you try you cant hardle move the...
Annoying solution, but works every time. Remove the ENTIRE bobbin casing from the base and then turn the wheel. The needle should lift right out. Reassemble bobbin casing and oil very well.
This generally only happens when you are sewing through several layers of fabric or though a thick fabric. If you are doing neither, the timing in your machine may be off and you will need to get it repaired.
Jul 04, 2010 | Singer 3116 Simple
Yamata FY920 Logo
187 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
