Question about Sony Handycam DCR-TRV103 Digital Camcorder
Flashing code C:32:11
The camera was dropped while holding it (30 inches). It appears ok, but when I turned it on, it made a rapid beeping sound and flashed code C:32:10. I turned it off. I tried to eject the tape but it wouldn't eject. No motor sounds. I removed the and re-connected the battery, and it made rumbling sounds from beneath where the tape is. That stopped, and nothing happened. When I turned it off and on again, I received code C:32:11. Repeating on/off, or battery removal causes the same responses noted above. I can't get the tape to eject and don't want to break it. Am hoping there is a user fix. Any suggestions are appreciated.
  • 2 more comments
  • artemisjim Feb 24, 2008
    I have exactly the same problem. How do I fix this?
  • Anonymous Aug 30, 2008
    same exact problem as the one described above, including the same error code.
  • Dooranie Sep 27, 2008
    After Inserting new tape into DCR-PC120E received error message C:32:10 and the tape will not eject not showing any likelihood of coming out. Tried battery out and mains then get C:32:11 and no sign of tape ejecting.
  • de_ridder_ti Feb 22, 2009
    it is not working for my camera dvx 2100
USE THE MAINS ADAPTER....TAKE THE BATTERY OUT, AND CONNECT MAINS ADAPTER THEN IT SHOULD WORK THEN TRY EJECTING THE TAPE AGAIN
Posted on Sep 04, 2008
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
On startup, 3 beeps
the beep codes are different for each BIOS mfg.
you can easily get a list of codes and their meanings from the internet.
Sep 04, 2012 | ZT Group Cisnet PC Desktop
Olympus VR-340 Won't turn on, lens won't retract.
My camera vr-340, when starts a sound appear and sacreen becomes black . what is this?
Jun 20, 2012 | Olympus Vr-340 16mp Camera Digital Optical...
The Dell 1357 laptop has Vista Home Premium and is as it was purchased. When booting, the computer beeps rapidly for about 30 seconds, displays an opportunity to boot into Vista, and then beeps for another...
If it is actually booting into Vista, it sounds like maybe you have a stuck key. Turn the computer off and press every key a few times and see if any of them feel "stuck". Even if they don't, pressing them may have released any sticking they had. I would try that first.
Jun 24, 2011 | Dell Studio 1537 Laptop
Need to reprogram the code but lost the manual
Hold down the 8 key until 2nd beep sounds. Enter the User Program Security Code. If this code has never been changed enter the default of 1+2+3+4+5+6. When the correct code has been entered the 1st 3 LED's will flash and the sounder will beep rapidly. Press the B/A key and then enter the User Code to be changed (1,2,3, etc.). Enter up to 4 numbers for the new code. Press the B/A key twice to exit the Program Mode. Hope this helps.
May 22, 2010 | Home Security
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Not able to shoot photos
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Mar 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera rapidly beeps 6 times when powered up and immediately turns off!
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Dec 18, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Handycam DCR-TRV103 Digital Camcorder Logo
2,132 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
