Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Drying problem Hi Our 3-day old LG dishwasher is not able to dry our dishes. After the cycle is finished 2 hours later, I open the door to find that water is everywhere. As if the washer is skipping the dry sequence completely. The "vent" on the inside of the door doesn't seem to have an outlet--why is this a vent if nothing can escape? The owner's manual says to use a rinse aid to help drying. I don't believe in using band-aid's; something else is wrong. Any help/advice is appreciated. Thanks, Kris
  • 4 more comments
  • JAB48 May 16, 2008
    I have the same problem I was told by an appliance store owner that they had a problem with this issue. The fix is to change the fan use a larger duct and I also use a bigger heating element.
    I AM NOT TO HAPPY WITH DISHWASHER.
  • Rodrigo Sisti Feb 11, 2009
    Hi mzpeder,
    I have the same problem with my dishwasher (the heater never goes on), and cannot get neither hot water nor dried out dishes. As I am living out of the US, would you clarify which board is the one you had to replace ? I noticed there is an electronic board in the bottom of the dishwasher and another control (display) built in the door. Which one was deffective in your case ? Thanks.
  • MOTRSPRT Mar 17, 2009
    Well, since I am the original poster of this thread I just read the resolutions to this issue today. I finally got one email verifying me of posts to this thread :) Oh well.
    Anyway, I have resorted to using a drying aid in order for my dishes to get dry. I know the heater element is working because if I open it at the end of the cycle the air is extremely hot--but moist. (In fact, if I run the washer the night before and open it the next morning the air is still warm.) Hence, the dishes remain wet with hot water. The idea of the air vent in the door recirculating the air to the tub is interesting. I don't know where the air would exit to the tub. Bottom of the door? Someone mentioned a fan in the door that runs while drying the dishes so I'll have to listen for the fan running.
    Bottom line, my dishes are only getting dry due to the rinse aid I'm using for every wash. Maybe I'll let the rinse aid run out and see if something has changed in the dishwasher over the past year. Maybe the valve in the door vent was stuck and it's working now? I dunno. I'll try and post my results later to keep this thread somewhat informative for other owners.
    Thanks.
  • MOTRSPRT Mar 23, 2009
    Well, so far so good. I have flushed the rinse aid dispenser several times to make sure there is no residual rinse aid still left in there. And, the dishes are still coming out dry. I wouldn't say my issue is 100% solved yet because I am not 100% sure that dispenser is completely rid of rinse aid. However, not once yet in the past week or so my dishes have finished wet. When the dw was new the dishes were as wet as if I sprayed them with water, so I'm hoping that something has changed...:)
    Thanks.
  • MOTRSPRT Apr 02, 2009
    Meyerjr,
    Here is the serial # to my dishwasher: 708KWBY01429
    Here is the model # to my dishwasher: LDF6810ST/01
    None of which seems to match your expected #'s though...
    Thanks
  • james_smi7 May 09, 2009
    I have the LG model # LDF6810ST/01 SN 705KWJUO3444 - it's not drying.. Can you help?
    Problem Solver:
  • 5 Answers
As I had the same problem, I worked on my machine and found out the heater unit was not working (it is a brand new machine ! - remark : as I moved overseas, LG did not cover it with their warranty).
But back to what I did : I ran the check program (instructions can be found in the Service Manual) and verified it was sending voltage to the heater on step 36. So I checked the heater unit (in the bottom of the machine) and found it was burned or open. So I ordered a new heater assembly ($40 on eBay), replaced it myself and am completely happy with the results.
Remarks : the heater is powerful enough to heat cold water to the temperatures required (I don't have hot water in the faucet); it seems that the heater also produces heat for the drying cycle (my dishes were completely wet at the end of the cycle before, now they get completely dry). My only disappointment, mentioned by some in the forum, is that the outlet during the drying cycle is in the bottom of the door, so steam condensates into droplets on the kitchen floor. But now I get clean dishes, and this machine is amazingly silent and efficient. Good luck to you !
Posted on Mar 17, 2009
Hi Motrsport,
I have the exact same problem with a new LDF6810ST. But it took me a month to realize.
The vent in the door DOES have an outlet. It has both a valve and an active fan to drive dry air in and moist air out - through vertical ducts to the left in the door assy. You can actually see the rubber cap of the valve through the vent grill in the door and weakly hear the fan when it runs, approx. last 30 min. of cycle.
Now I have had the unit serviced twice through LGE, the tech found that the motherboard in the board was not turning on the heater in step 36 (service mode). I am now awaiting a replacement of the motherboard and the heater by local LGE rep.
So call LGE for service while you are still under warranty. You should not accept soaking wet end of cycle.
Posted on Apr 23, 2008
  • Mike Pedersen Apr 02, 2009
    Hi all,
    My problem was never solved with the first unit LGE could not bring the heater/fan to work after 4 visits. In June 2008 we got a replacement new and modified model LDF6810ST/01 installed. It worked fine for 1.5 month then it had a major leak all over my kitchen, damaging my wooden cabinets, after another two repair attempts, I forced LGE and Home Depot to take everything back. Their customer service was very unpleasant, they never appologized or offered to cover some of my lost work time - being home for six repair attempts + one re-install.
    I see no need to write my opinion about LGE.
  • 3 Answers
My LG is 712KWEL00012. Is this eligible for retrofit? How do I ask for it?
Posted on Nov 27, 2009
  • 423 Answers
If you post your serial numbers of your LG dishwasher model numbers ending in the numbers xx11 and XX12 we can check to see if they are eligible for a retrofit that can dramatically help with the drying. The initial design in the earliest models of these LG dishwashers were flawed.
Also, these dishwashers are not designed dry well without a rinse aid. Some folks have had good luck putting white vinegar in the rinse aid dispenser, but your mileage may vary.
Posted on Apr 02, 2009
  • rickvoo66 Apr 10, 2011
    I'm not a plumbing professional but I just replaced an LG dishwasher heating element. Wife complained dishes weren't drying and there was a bad odor inside the dishwasher. To me, it was clear that the sump heater wasn't heating the wash and rinse water. Not difficult to do. As mentioned above, disconnect water supply line by removing small panel at the bottom front. Make sure to turn water off first. Then disconnect dishwasher drain tube under your sink, this allows dishwasher to be pulled out of cabinet. Turn dishwasher over ( easy, very light weight). Remove sheet metal pan on bottom to expose the sump, motor, pump, heater etc. You'll see the ends of the heater element sticking out of the sump assembly. Usual instructions recommend removing the large plastic base but I found that the heater could be removed and reinstalled by simply sliding it out and into the gap between the plastic base and the washer cabint once I removed the sheet metal side panel on the dishwasher. I tested my heater with a volt-ohm meter and found it to be defective ( this is what I hoped for since new heater is only $50). Got new heater ( SEE PICTURE) and installed it in about 30 minutes. The only fussy part was knowing how tight to turn the small bolt which squeezes the rubber seal. I was conservative the first attempt and had a water leak where the heater fits into the sump. You'll see this and understand how the bolt and rubber seal work once you get the heater out. Turned the bolt more and the leak stopped. Washer works great now, wife happy. Congratulate yourself on saving $200. My dishwasher is LG Model LDF 6810ST. Damn expensive so I'm glad this simple fix worked well. Bought heater from repairclininc.com
    President:
  • LG Master
  • 2,651 Answers
Be sure to select if possible a cycle with heated dry or that heated dry is not unselected, d/w now are designed with rinse aid in mind, not really a band-aid but a legitimate action. and yes there is a vent w/ no exhaust. its actually a very clever active vent that returns moist air(thruough a channel within door assy) back to bottomof tub. itsjust steam all condenses to water droplets inside. why heat your kitchen with it.
Posted on Feb 23, 2008
Dishwasher not completely drying
The dishwasher does not dry the dishes, it is the residual heat remaining from the washing water that dries the dishes.
Once the washing cycle is over, opening the door and pulling the top drawer out slightly to keep the door ajar will create a small opening which allows the steam to escape and the dishes then dry a lot quicker.
Jun 06, 2014 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810 not drying dishes
I have also found this happening. I have found that if you switch the dishwasher off 2-4 minutes into the dry cycle and leave it for a few hours or over night the dishes are completely dry
Jun 12, 2012 | LG LDF6810 Built-in Dishwasher
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
Dishes are not drying at the end of cycle there is no heat
if its a ss or lg its normal open the door at end of cycle
May 30, 2010 | Dishwashers
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Does Not Dry Dishes
Withe the model and serial number it appears that this dishwasher is less than 2 years old.
Your symptoms point to a failed heating element. That is kind of surprising because this dishwasher ~should~ report an error code if the thermistor does not detect the raising temperature from the heating element.
The LG LDS and LDF models do NOT turn on the heating element in the drying cycle. It turns it on during the final rinse and the dishes dry as the built in fan runs.
So, I suspect the drying fan and related gear is inside the door panel. Do a load of dishes and listen for the final rinse to drain. Then, listen really closely near the top of the door for the quiet sound of a fan _and_ place your hand underneath the left hand side of the closed door for warm air blowing straight down.
If you do not hear./feel what I discribed , the drying system has failed. OH, and if you have any water leaking from the door (right where the warm air is supposed to come out, contact LG service folks and firmly request that they replace the drying parts with a retrofit kit.
Please review this and tell me what works and what questions you still have.
Good Luck and please keep me posted! OK?
Mar 24, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG7810 will not dry dishes
THE DRY CYCLE HAS A PORT ON THE INSIDE OF THE DOOR WITH A BLOWER MOTOR. THE PORT SHOULD OPEN AND THE FAN MOTOR COME ON DURING THE DRY CYCLE TO EVACUATE THE STEAM FROM THE INTERIOR. THE PORT IS OPENED WITH A WAX MOTOR. IF IT FAILS, THE PORT WILL REMAIN CLOSED AND DRYING WILL NOT TAKE PLACE.
TO VERIFY OPERATION, WHEN THE DRY CYCLE STARTS,
WAIT ABOUT 2 MINUTES, THEN OPEN THE DOOR AND LOOK IN THE ROUND VENT ON THE INTERIOR OF THE DOOR. IT SHOULD BE OPENED. IT WILL SLOWLY CLOSE AS THE DOOR REMAINS OPEN. YOU SHOULD BE ABLE TO SEE THIS ACTION.
Mar 31, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
1,110 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
