Question about Refrigerators
No water at the dispensor
I have a GE side by side fridgerator and I dont get water from the dispensor. I checked the line at the bottom of the door and it comes out there. I tried to blow the line out that goes to the dispensor with no luck. I undersrand it could be frozen. Is there a easy way to checkout the line?
  • Slicko Feb 23, 2008
    Please help
  • 24 Answers
Check the temp inside your fridge with a thermometer. You may well be frozen up.
Posted on Nov 08, 2009
    President:
  • Refrigerators Master
  • 2,651 Answers
If you can disconnect below door and water works then for sure it must be cloged inside door panel.i got one of those steam machines advertisedon the tv for cleanin your house that i use for defrostin frozen drain tubes, evaporators, cant see why somthin like that wouldnt work
Posted on Feb 23, 2008
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
Water dispenser not working,
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours so the heat will thaw the " hook " , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
May 15, 2010 | GE GSS20IEP Side by Side Refrigerator
I dont have any water coming from the dispenser i do have water coming out of the hose beneath the door from the solenoid my question is is there another solenoid inside the door of the freezer im thinking...
The water line in the door is frozen . Several ways to thaw . 1 ) turn on the dispensor light for a few daws until thawed , 2 ) raise the freezer temp a few days until thawed , 3 ) use compressed air to the bottom of the door on the line , to blow out the ice , 4 ) order the GE dispensor heater pt. # WR49X10173 , it comes with installation instructions .
May 09, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser does not dispense water GSS25LG
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 , with installation instructions , to keep this from happening again .
Jan 19, 2010 | GE GSS25LGM Side by Side Refrigerator
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE SS Side by Side Refrigerator is not dispensing water; makes ice just fine. Is this a problem that I can fix without a service call?
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Dec 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
No water thru door
I am having the same problem with me GE side by side. I check my gasket and I don't have any screws so I assume that I have a "foamed in place" doors. I did notice when took the front of my ice / water dispensor off the circuit board has a connection named "heater". Is there any way to check heater and if it is bad how and where do you replace it. Thanks.
Oct 29, 2006 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
