Question about AMD Athlon 64 x2 3800 3800+, 2 GHz Processor in a Box (PIB)
Screen won't display,
When i boot up i can see by the flickering led's that it's running but nothing on screen, i have replaced the motherboard and processor, but still it won't stay on, it comes on for a second then goes off, windows log on shows for a second then goes off, it won't stay on long enough to even type my password, but if i type my password youcan see the pc working, i'am at a total loss
    President:
  • 2,351 Answers
Did you plug in the 4-pn 12v_ATX connector loacated on the board near the CPU? Ya got to have this or your the CPU will stop you in your tracks.
Posted on Feb 23, 2008
I have a foxconn motherboard (G33M02) and the LED is flashing orange and it will not power on. I have used the PSU on another computer and it work and when i used a different PSU the LED is steady orange...
 In that cse you must try 2 more things:
1 - remove all disks and try to boot in the BIOS - if it works then one of your disk is dead and blocks the motherboard. Find it by elimination and replace it. If it doesn't work then
2 - replace the memory, video card  and processor (in this order) and again try to boot in the BIOS. If everything fails then your mobo is dead, replace it.
Aug 11, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Asus rampage 2 extreme no beeps on first boot, does not enter post, i.e nothing shows up on screen, with the 8 pin power connector in the motherboard the pc will boot then shutdown for 2 seconds and reboot...
1 - Test the memory in another pc; if it's at fault change it completely.
2 - That 8 pin connector is there to provide extra power to the processor sources - either one or more of them are fried = replace motherboard or the processor itself is gone =  test it in another pc and replace it if necessary.
Oct 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Nothing happens on screen when booting computer
Hope this helps
Oct 06, 2009 | Abit AN-M2HD Motherboard
Graphics card problem?
You are pushing the hardware you have. Is your board, processor, power supply ample enough? It is best to check running processes and programs to see if you are spiking your systems ability to perform.
Sep 27, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
AMD Athlon 64 x2 3800 3800+, 2 GHz Processor in a Box (PIB) Logo
65 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
