Question about Canon PIXMA MP600 all-In-One InkJet Printer
My canon MP600 PRINTER
My canon mp600 is showing error code 5100 and 6A00, do you know what this means and how to fix it?
  • 2 more comments
  • thinkreilly Feb 24, 2008
    It says there is no paper but i have filled the tray and it still does not recognize it. can you help please?
  • Samaroni Feb 24, 2008
    I have that same error code - A600, and these steps do nothing. It was working great a moment ago!! Argh.
  • Anonymous Jun 15, 2008
    Yes same problem --- Canon mp - showing Error 6A00--- what can I do
    Jane
  • jane53 Jun 15, 2008
    Same problem------ Canon mp600 --- error code 6A00
    what can i do
    Jane
    Scholar:
  • 41 Answers
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
When I open my canon mp600 show me an error code "6A00" what should I do ?
There is a prblem with the carriage lift mechanism.
Probale causes
1.PR
Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local
Canon Dealer will know for sure!
Mar 01, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma MP600 error code 5010
My Printer is coming up wiht a printer error B200, and i dont know what to do about it.
Jan 15, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 error code U043
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all in one inkjet printer
error code u052 is a print head error that means the print head is faulty If unit is still under warranty should cover the printhead. Go ahead and call canon support number for your region or go online to canon website for closest Authorized Service Facility and they will take care of it for you.
Good luck
Sep 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
362 people viewed this question
old marine
old marine
