Question about Kitchen Ranges
Those darn screws!
Hi, gang...
I asked recently about the tripping circuit breaker and my Maytag MGR6775ADS stove. It appears that one of the spark switches has been shorting (evidenced by small smoke signals when the breaker is reset). After deciding to order the parts, I figured if I disconnected the spark switch circuit, my wife could use the oven, which needs the computer to run.
Long story short (no pun intended) - when I reset the CB, my wife yelled "It's on FIRE! TURN IT OFF!" (50-50 chance of disconnecting the one wire that was hot to the short...)
Anyway, the top part of the burner is held to the jet orifice section through the stove top assembly by two screws each. If the burner tops can be removed, the whole stove top can be lifted out to access the valve and switch area without risk to the gas pipes. These screws have endured several years of cooking heat and look pretty corroded and scorched. They are very tight. I don't want to break them off if I can help it
The question is: Is there a professional's trick to getting these screws loosened?
I've been advised to use penetrating oil (trying liquid wrench on two of them, being careful that it's fully evaporated before cooking on the other two - repeated applications projected over 2-3 days).
Or is the professional's way to replace the anything that gets bunged up in the process as a part of the necessary procedure?
Or is it to only bend things just enough to get the switch harness assembly out and replaced?
No disrespect intended. I just know pro's have learned good methods that aren't in the manuals.
Thanks,
G00k
  • Steve B Feb 23, 2008
    Thanks, Big T and aborcass...
    I have been hitting the screws (the directions on the liquid wrench can suggests that), and so far it budges only a tiny scootch, but then no more.
    I ordered the screws at the same time I ordered the switch harness - hopefully they will be the right ones - we'll see if I can drill 'em out.
    G00k
    (BTW: it's a childhood nickname fracturing my last name, not a slur, and rhymes with book.)
  • 640 Answers
Gook, another suggestion would be to shock them.Insert the screwdriver into the screw and hit the end of the screwdriver with a hammer.Do it lightly so you dont ding the oven up.Another way is to use a mapp torch and heat them up.
Posted on Feb 23, 2008
  • anthony james
    anthony james Feb 24, 2008
    You could also try a small chisel punch to start them to turn.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
My suggestion would be to get out 1 screw bring it to hardware store, buy 8 more. drill out remaining screws. problem with "bending" top up enough is you chance loosing other gas lines.
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Electric stove
Check the thermal coupler a copper thermometer for your stove after checking all the fuses in stove and circuit breaker box of house to see if any have tripped. Circuit Breakers should have the switches all in a line. Any not in the lie will be tripped. Fuses in your stove are usually in the top part of the stove where the instruments are and fuses screw out and visually are easy to detect if they are blown or not. Remember all ways Unplug what you are working on to prevent shock
Jul 03, 2013 | Ovens
The stove made a popping sound and the circuit breaker popped.i reset the breaker and it popped instantly.
Since you have a gas kitchen range, finding the problem should not be that difficult.
1. Make sure all switches are in the off position. Then reset the circuit breaker. If it didn't trip, then turn one knob on at a time (and then off) until it trips.
2. If the circuit breaker triped with all knobs off, then it would have to be something that is always on like the 12V transformer.
Hopefully, this wiring diagram will be of help.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MGR6772BDS/3048/0124002/M0604023/00009
Jun 23, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
Jun 23, 2010 | Kitchen Ranges
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Apr 24, 2009 | Maytag MGR6875BK Gas Kitchen Range
Maytag stove mer6769baq trips the breaker whenever plugged in
It sounds to me like there is a short circuit either in the plug or the connections at the stove. It could also be within the stove although that seems very unlikely. If this happens when your using the stove, the breaker and circuit could be undersized (required breaker size-50AMPS) Check all wires and the breaker.
Apr 01, 2009 | Maytag MER6769 Gemini Electric Kitchen...
My admiral stove stopped working, the elements just arent on anymore, but the stove has power because i plug my toaster into the socket on the stove and it still works, and everything else in the kitchen...
first thing is to check you r circuit breaker,is it an electric range ??? or a gas stove with electronic iginiton???, if its a full electric range then youll have a double breaker powering your unit, and its possible that one of the breakers tripped, allowing only half power to the unit.if its a gas with electronic igniton then slightly different matter and then i would ask of the top elemnts will light with match and perhaps theres an issue with the electronic spark switch
Oct 22, 2008 | Kitchen Ranges
Getting those darn screws out
suggest removing one screw, takinit to hardware store andgetig 8 more, drll out existing screws and remove entire top, why mess with bending gas lines not worth the trouble
Feb 23, 2008 | Kitchen Ranges
Kitchen Ranges Logo
127 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
