Samsung HL-R5067W no picture or sound.
Had the reboot problem 3 months ago, set would warm up, shut on and off until i pulled the plug. Tech dispatched by Samsung replaced the digital board, lamp and DMD. Set worked for 3 months. Now set will turn on, no picture or sound, lamp light blinks and then set shuts off. Took off the bulb panel and held in trip switch, tried to power and got same result, but bulb seems to be getting plenty bright. Ideas?
  • 2 more comments
  • bj5487 Sep 30, 2008
    I have the same problem on my HL-R5067WAA/XAA model less than 2 years old.It has never been worked on.I tried the procedure of mute-1-8-2 on the remote control with no success.
  • BTEAL Nov 04, 2008
    After being on for a while, then turned off, it will not turn right back on until it has cooled off for a couple hours. After trying to turn on with the remote, it will start to go through the sequence of turning on, the tones will sound, the lights flash, then a high pitched whine will come on, go off, never getting a screen picture, and then it will go back through the same routine until all lights are on, unable to turn on. It appears to be a heat related problem to me. It has to cool off for a long time to enable it to work. Otherwise the picture and sound is excellent. Bill Teal
  • xrays123 Feb 26, 2009
    Samsung HL-R5067W power cycles on its own. Replaced bulb, no change. Beep sounds, image comes up, 12 seconds later image freezes and TV power cycles. I can control the TV when it the image is live via the remote.
  • Hookup2 Apr 09, 2009
    When I power the unit on I get no audio, video or audible chime. I here a clicking and the Lamp Led blinks. I have no control with the remote and can't even shut the t.v down. After about a minute the tv powers itself off and the temp LED illuminates.
I have an HL-R5067W  no picture, no sound.. What is the solution
Posted on Mar 13, 2009
How do i replace the ballast in a hL-T5075S
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Replacemsnt procedure to both lamp and ballast to projection TVs are given with illustrations.
Apr 20, 2014 | Samsung HL-T5076S 50 in. TV
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
I have a Samsung HL-R5067W. I have had this tv
the digital pcbs on these sets go bad and need to be replaced when they start showing these symtoms
Jan 23, 2010 | Samsung Televison & Video
No picture but only sound
your AV cord is broke, Radio shack has them ask for a universal, _whatever item your trying to use_ cord,
Dec 27, 2009 | Televison & Video
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
No sound or picture HL-R5067w samsung
See my TIP on my page and see if that helps u. Also the lamp could be toasted. Let me know, i may have one in stock. Thank you GURU JAY
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
Televison & Video Logo
1,040 people viewed this question
Top Televison & Video Experts
