Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Heater blower quit working on my 2005 yukon. fuses appear to be O.K. any advise on what to look for next?
  • 981 Answers
Look for:
More fuses, a blower relay, how the heck this relates to Dell Flatpanel Monitors; some wrenches and rubber gloves (over a liner glove if it's cold!), small animals hording food or nesting in your blower area (and thus likely also a bad air filter), a bad blower motor (or brush component) or drive circuit, or a heating element sensor whose sensibilities are lost or disconnected and thus telling the controls to chill until that's fixed.
I hope that if your Dell's stuck in the blower that this makes a good story on film.
Posted on Feb 23, 2008
My 2005 yukon has no ac blower fan control
check the resister next to the blower motor they burn out
Sep 25, 2012 | 2005 GMC Yukon
My 2005 gmc yukon rear a/c or heat blower will not come on front a/c and heat work well
{: ) If the front a/c and heater is working fine, that's good. At least the problem can be isolated on the rear HVAC circuits only.
Check first the RR HVAC fuse 30amp at the underhood fuseblock and the IGN 3 fuse 10amp at the IP fuseblock. If you found them good, then you can begin diagnosing the blower circuits wirings and connectors.
A faulty blower definitely will not give any output. If it doesn't spin for some reason, rear a/c or heating cannot be circulated.
A faulty blower resistor or speed control processor can also cause a zero air output. Sometimes, the blower may only work at certain speeds only.
A faulty rear HVAC control switch may not give the proper signals to the blower resistor or speed controller, and in turn will render the blower motor disabled.
Sometimes it can be a terminal connector being loose or burnt. However, the most usual cause for this type of problem is a faulty blower resistor.
Jun 12, 2011 | 2005 GMC Yukon
2005 Yukon XL Denali: Heater Blower jsut stopped working?? Is it common for the fuse to go out in these? or something else
Does it work on any speeds? If it still works on high then the blower resistor is bad. On the passenger side under the glovebox is the blower motor and resistor.If possible try wiggling the pigtail plugs that attach to these two components.It is not uncommon to have problems with these pigtails.Also try tapping the bottom of the blower motor to see if it will start working again.If it does The connections are poor and need repaired. If the blower will not work at all check for power at the blower motor pigtail with a test light or dvm. Will be glad to assist further if more assistance is needed.
Oct 26, 2010 | 2005 GMC Yukon Xl Denali
My 2005 Yukon AC blower is not blowing. THe
There is a service bulletin for this problem which replaces the blower resistor and connector. Mine had the same problem while on vacation. No fan speed control, and when it did work, the fan would keep running after the vehicle was shut off. Mine is currently in the shop getting the service bulletin installed.
May 31, 2010 | 2005 GMC Yukon
Driver seat heater only stays on for 15 seconds. If I only turn passenger seat heater on, passenger side works fine, when i add drivers side, both shut off. 2005 1500yukon XL Also heater blower just stoped...
No biggy.The seat heater can be repaired by the dealership.Should not cost much because there are no parts just a reprogram of the drivers seat module.The blower motor is the blower motor resistor module.It is on the passengers side under the dash next to the blower motor.You should be able to do this yourself if you have a little mechanical experience.Hope this helps.Good luck.
Jan 29, 2010 | 2003 GMC Yukon XL
The blower motor for my 2005 Suburban suddenly
Check voltage at the terminal that connects the blower if the problem is the current blower because eventually the brushes wear out
Jan 09, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Heater fan on 2002 Yukon does not operate in front, only rear.
The front blower motor is controlled by the blower resistor module.This is usually the problem with the front blower not working.I looked up the schecmatics and I don`t see separate fuses for the front and rear.But the fuse for the front blower is in the under hood fuse block.If this is good then The problem is probably the resistor module.It is next to the blower motor.The connector from the resistor connects to the blower motor.If you want to confirm this you can check for power and ground at the blower motor connector when you activating the blower switch on.This can be done with a test light.Make sure you have power going into the resistor module also.If you have power going in and no power at the blower motor then replace the resistor.Hope this helps.Good luck.
Dec 28, 2009 | 2002 GMC Sierra C/K1500
Heater in 1993 Yukon quit working
check fuse first,
switch second,
blower motor resistor third,
blower motor last
Dec 27, 2009 | 1993 GMC Yukon
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
97 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
