Question about Hotpoint REM25SJ Microwave Oven
Erradic operation of the microwave oven
Greetings, When I turn on the microwave oven it will shut off without completing. The shutoff is generally preceded by flickering in the display panel. Sometimes it will operate to completion, quite bizarre. When I turn off the turntable it still works erradically. I have changed the outlet the unit is plugged in to but that has not made any difference. Does anyone have any suggestions? Greetings, It seems that I have exactly the same problem. The microwave is out of warranty for 1 month and 15 days! Calling GE service they ask for a price which will not justify the repair. I opened it hoping to see something obvious. Not easy to spot the problem. I purchased it because the space I had was small, under a cabinet. Also the price was reasonable. The question I have is: should I buy the same model? Or this is model is really a lemon?
    Genius:
  • 1,226 Answers
Hello;
Maybe the microwave oven is come to an end. However may you can try fixing that by a series of a test unsing the tester device. Maybe there is a automatic sensor that eradically not function properly.
In this case; i would suggest you to open the circuit and test some part that is not working properly.
Hope this help, melnavz
Posted on Feb 23, 2008
  • 552 Answers
First try moving the power cord around. If you notice any change in behavior, most assuredly you have a problem with the cord itself or where it is connected in the microwave.
If not that, unplug it and open it to see if there are any loose connections, wire etc. inside.
Because these simptoms are erratic, there seems to be a short/loose connection that causes changes in the way the unit operates with movement/vibration.
    Scholar:
  • 121 Answers
Hi.. i'm sorry to hear your problem..
i have a link that may help you figure it out more in depth..
http://www.hotpoint.com/metallic/microwaves.htm
good luck but if i was both of you, i would not buy this model again since it seems to be a faulty model.. thanks, d
  • donna mcgill Feb 26, 2008
    have you resolved this issue? i hope i was able to help and if so, please let me know so i can also close this solution... if it was helpful, feedback would be great. thanks, d
Repair to microwave oven
The door interlock may be broken or may have gotten food jammed in it.
Sep 05, 2012 | GE JVM1850 1000 Watts Microwave Oven
I have a panasonic microwave oven. It shuts off after running for just a few seconds. It does not flip any circuits. The model # is NN T785SF.
It thinks its overheating, and the (faulty) thermal shutoff is shutting down your unit.
fix: since repair parts for household appliances are unavailable (parts are available for major
appliances only), your fix is to replace the microwave.
Or give it to the handy kid down the block who will disable the thermal shutoff and use it to
melt plastic stuff for demented puerile YouTube videos...
Aug 17, 2011 | Panasonic Microwave Ovens
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
The microwave was accidentally used without the glass turntable
It mkay just be the overload fuse inside the back panel. I highly recommend a certified electrician or repairman to change this. Good luck
May 11, 2017 | Microwave Ovens
Turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Nov 05, 2008 | Panasonic NN-T990SA Microwave Oven
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
Shuts off
Greetings,
Thanks for your inquiry regarding the issues you are experiencing with your microwave. What it sounds like is a possible short internally otherwise it might also be over heating.
How long have you owned your microwave for?
I'll await your reply.
Dec 28, 2007 | Samsung MW1030WA Microwave Oven
Operating a microwave oven without a load
In principle no it is not hazardous. In practice however, unless the machine is clean to the point of sterile, small items in the microwave can absorb more energy than they would if a large item was in the machine also. This can produce some damage to the machine. manufacturers generally recommend not running microwaves empty. Why would you want to? If in doubt, just a cup of water would be more than adequate. it is not a good idea to modify a microwave oven in any way. Hope this helps :)
Aug 17, 2007 | Emerson MW8626W Microwave Oven
there is probably a loose contact in the pc board at the front or alternatively the powersupply in the mwave .canbe a number of diff things sorry i could not b of more help
Jun 04, 2007 | Hotpoint REM25SJ Microwave Oven
Hotpoint REM25SJ Microwave Oven Logo
90 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
