Question about Kenmore 71279 Bottom Freezer Refrigerator
Water leaking onto floor
Refrigerator was moved to another room to replace damaged wood floor due to break in water line on washing macine. Floor is replaced and refrigerator placed back in kitchen. Refrigerator was only unplugged for about 5 minutes each time it was unplugged. We turned water back on to use the ice/water dispenser. Two days after, noticed water on floor coming from front of refrigerator. It is not coming from water line tube. Ice is building up on bottom of freezer. I remove ice and it builds up again. We shut off water line to freezer. All ice is out of ice maker. Ice built up again on freezer floor. Can you help ??? Don't want to ruin wood floor with water again. angels My Kenmore bottom-mount refrigerator (this means the freezer is on the bottom) has a huge build up of ice in the bottom of the freezer. To the point that half the space in the bottom rack is ice. Why does this happen and can I stop it?
  • 1 more comment
  • Anonymous Mar 16, 2014
    ice in bottom of freezer melts an comes out on floor
  • Anonymous Mar 24, 2014
    Water runs on floor during thaw cycle
  • Anonymous Mar 29, 2014
    The ice builds up under the freezer basket and then drips on floor
    President:
  • Kenmore Master
  • 2,651 Answers
Unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
Just wanted to say thanks to Ron Merek for his solution to water in the bottom of my fridge and running out into the floor. I poured boiling water into the drain whole behind inside panel which melted the ice clog and melting the rest with a hair dryer. But I couldn't find drain pan to empty it afterwards. Where does the water go? And how can I prevent this problem from happening over and over again???
redoctobermh
Posted on Jul 07, 2012
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
Water leak onto floor
There should be a drain pan that is deposited into, however some will crack or be moved out of place causing this.
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
Water drip on to floor from rt.rear. profile side by side
Tube may be a ice maker supply line. You can replace it at any home depote
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
My DFF1170W Top Freezer Refrigerator is leaking on the floor, what should I do?
If you have a ice maker or water dispencer check the water line conected to the back ! If you move the fridge alot some times the water line can get damagged.
Jun 22, 2012 | Danby DFF1170W Top Freezer Refrigerator
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Sep 11, 2009 | Refrigerators
Water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
Sep 04, 2009 | Frigidaire FRS26R4A Side by Side...
Leaks water onto floor while in use
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Jan 19, 2009 | Washing Machines
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
Kenmore 71279 Bottom Freezer Refrigerator Logo
1,283 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
