Question about Kenmore 15522 Built-in Dishwasher
Diswasher won't run
I started the diswasher and it appeared to be running, however, I opened the door to add another dish; now it won't run, won't add water. I checked the circuit breaker and tried opening and closing the door again. I turned the knob so it would go through all the cycles; won't run. Any ideas?
  • babykitty Feb 14, 2009
    The rinse water does not drain and will not turn back on after closing the door. I checked the breaker, but that is not the problem. The lights come on the front panel but nothing happens.
  • Anonymous Mar 28, 2014
    Run a cycle when leaving for a few days then when return Door won't open. Only way to open is too run cycle again then it opens.
    President:
  • Kenmore Master
  • 2,651 Answers
First check the circuit breaker box you might hva tripped abreaker, next close the door softly, and listen to perhaps hear the door switch activating, id the door doesnt close (bad switch) no power to rest of d/w
Posted on Feb 23, 2008
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
I have an Electrolux ESL6115 dishwasher model and although there is water coming out and the spray blades seem to be turning the dishes are always wet after the cycle has finished and there appears to be...
Its possible that if you live in a hard water area that limescale buildup is causing this problem if salt levels got low. The first thing that can be done is to run it with 2 or 3 cups of vinegar added & see if it cures it. If it won't accept opening the door to add this after wash has started then add it in a wide dish to catch water & wash it out during cycle. Adding a dose (half cup) of bicarbonate of soda alongside should work even better. This has worked really well for washing machine about to give up on & do regularly to prevent problem. Hope this helps.
Apr 28, 2011 | Electrolux 23 in. ESL6114 Built-in...
Whirlpool gold diswasher - sudddenly dishes/glassware/silver are all cloudy. rinse aid doesn't help. have tried running machine empty to "clean out" pipes, etc. plz help.
alot of people think the rinse aid is full but, its not. how to properly fill unit.
1. open compartment
2.fill with jet dry
3.close compartment
4.lower and raise door 3 times
5. open compartment
6.add more jet dry
7. lower and raise the door to see if it still looks full.
the reason for this is there is air in the dispenser and this process will take out the air to be completely filled the dispenser.
Mar 05, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Jan 11, 2010 | Electrolux Dishwashers
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Dishes are not getting clean, detergent just runs down the door used tablets they worked until lately. The door would open but the tablet would not disolve. Now I use liquid but it just runs down the door...
Quickest way to ruin a good dishwasher is to use tablets. They have times when they don't brake down in the water like they were designed. Chance are that you used the tablets with the thin film package, this thin film gets caught in the pump and shut down water circulation. Have a qualified tech pull motor assembly apart for you and clean.
Nov 12, 2009 | GE Nautilus 24" Built-in Dishwasher
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 | Dishwashers
Diswasher detergent door
lizzie1 First thing check if the lower dish rack is in right position. If it is in wrong position it is not enough room for the lid to pop up open. Try to turn the dish rack around and see if it works. If not, then I'll need the full model number for your dish easher. Gendos...post back
Jan 28, 2007 | Whirlpool 24 in. DU850DWG Built-in...
Open Questions:
Kenmore 15522 Built-in Dishwasher Logo
349 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
