Brother P touch 1000 label maker language settings? How do I change it back to English. I accidently changed it to French!!
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
Could you please tell me if you know the same tip for the Brother PTouch 2460 (mine is in german) ? I tried to hold the delete and format (equivalent of F) buttons but it doesn't work.
Thank you very much
Hello.
Please, I have the same problem with my PTouch 2460.
How have you solved it? Thanks
SOLVED SETTING LANGUAGE PT 2460.
(1) Make sure that a tape cassette is loaded.
(2) Make sure that the internal memory has been initialized and the power is off. (To
initialize the internal memory, turn on the machine while holding down the Code and
R keys.)
(3) While holding down the Code and K keys, press the On/Off key to turn the machine
on. When releasing those keys, be sure to first release the On/Off key and then
release the Code and K keys.
The machine will enter the inspection mode (CHECK submode) and display the
following on the LCD: FACTORY CHECK
Then , press 2 and set the language
Phew thank goodness there are techno minded people to help idiots like me. Thank you
I am having a Korean keyboard version. The display language in Korean and now way I am able to change it to English. How could I change it. Please help. I have tried factory check by pressing shift + K key, but pressing 2 after that don't do anything. It seems this device has only Korean language. Is there a way I can flash the English firmware to it?
