Question about Orion TVDVD092 9 in. TV/DVD Combo
Playing nintendo game system on orion television
Have all the cables hooked up correctly but nintendo will not work. Seems that I should have button (input/video button)to push but there is neither on the remote.
  • 979 Answers
What input are you using on the back of the TV?
Posted on Mar 21, 2008
How do I hook up the Retro Duo nes/snes system to an older tv that has no a/v connections. I do have a Direct tv cable box but when I hooked the a/v cables to it absolutely nothing happened
Do you have a VCR that can hook to the TV that has the proper hook ups for your game system? Be sure your TV is on proper channel for your VCR to work (test it with a VCR tape and see if it plays) then change your channel on your vcr until it shows your game you have in your system hope that helps good luck
Dec 11, 2014 | Retro-Bit Retro Duo NES/SNES System Mascot...
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Feb 10, 2011 | Nintendo 64 Console
I havent played my super nintendo in a couple years and everytime i try and play it now i just get a blank screen...ive tried rehooking up everything multiple times but the screen is still dark....any...
Blank Screen
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.
Other Screen Problems
Dec 12, 2010 | Nintendo Super NES Console
Ive not played my super nintendo in at least 5 years. i hooked up to my tv and turned it on. the main screen for all my games were fine but when i went to play all you could see was the background. there...
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
If the above troubleshooting doesn't fix the problem, see below.
Try cleaning the game packs out with quips and rubbing alchoal.
Nov 27, 2010 | Nintendo Super NES Console
System turns off when playing the gameboy sp games after about a minute or two it just shuts off like you turned the power off .It works fine when I play ds games but no matter what when you play a sp game...
I would open the DS and make sure all the wires are hooked up correctly in the bottom slot if they are then call Nintendo and ask if they could repair it.
May 09, 2010 | Nintendo DS Lite
Wii input channel on DirecTV
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
nilkhet19
Dec 29, 2009 | Nintendo Wii Console
Can't get Leapfrog to work with Orion (13") tv
Use the TV/AV button on the remote to turn on the "ports".
Oct 13, 2008 | Orion Televison & Video
Orion Television problem
Hi. dvd pixelates when playing. have cleaned lens but still pixelates when playing. thanks.
Dec 27, 2007 | Televison & Video
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Orion TVDVD092 9 in. TV/DVD Combo Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
