Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Toshiba 52" rear projection
How do I get the setting to stay at theater wide 1. every time we change chanels or functions it returns to natural?
  • 552 Answers
   The theater wide feature 1 may not be available in all tv channel formats.
Try the downloadable manual at www.retrevo.com
Posted on Feb 23, 2008
Factory reset for ht-q20??
1. RESET
While "NO DISC" message appears on the display of main unit, hold the main unit's STOP button for longer than 5 seconds. "INITIALIZE" appears on the display and all settings will return to the default values.
Using the RESET function will erase all stored settings.
2. Firmware update
Upgrade File ver 1.3, All OS (ENGLISH) 18 Sep, 2007
Upgrade guide ver -, All OS (ENGLISH) 21 May, 2007
HT Q20
Dec 03, 2012 | Samsung HT-Q20 Theater System
Regza 42"
ok...so do you want to work this out? the user manual speaks to this...
Jun 03, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
NO VIDEO OR AUDIO ON ANY INPUT, BUT HAS MENU DISPLAY
If you try to change the chanel on the remote and you don't get snow, then your set is in home theater mode and stuck on EXT-1 input.
You will have to get into the menu under advanced settings and turn off Home Theater.
Hope this helps.
Thanks for using FixYa
Mar 02, 2011 | Mitsubishi VS-50609 50" Rear Projection...
All my chanels are blocked every time i change the chanel ive got to press the 1111 key every time to get the station
You've probably activated the parental control / child lock. This can be done accidentally by pressing a certain combination of buttons on the remote. To turn this off:
1. Press the "MENU" button on the remote control
2. Select the "LOCK" option (the padlock icon) with the left and right arrow buttons "" ">" on the remote
3. Enter the password. The default is 0000 but yours appears to be set to 1111. Try either or both.
4. On the next screem make sure "SYSTEM LOCK" and "UNRATED LOCK" are set to "OFF". Highlight each option with the up and down arrows on the remote and change the setting using "" or ">"
5. When they are both set to "OFF", press "MENU" again to return to watching TV.
All your channels should now be unblocked.
Hope this helps. If you need further assistance, please post back.
Regards,
BElectric
Dec 05, 2010 | AOC L24H898 24 in. LCD TV
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at meganetsl@yahoo.com
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Picture won't change sizes
If you are using a cable box, the settings you want are in the setting menu under "format" or "display" . Typically the choices are Normal or stretch, Select stretch.
The "small picture is how the old NTSC format displays in "normal mode" on a High definition set.
While you are in the settings menu, you might want to verify that the box is set to output at least 720P if not 1080i.
www.mcveyelectronics.com
Apr 07, 2009 | Toshiba 42HL167 42 in. LCD Television
Yes...
Ok I'm being told to try a couple of different things... nobody seems to be 100% sure of the factory reset on that model.
To reset your Samsung home theater system, follow the steps below:
  1. While NO DISC message appears on the display of the home theater, hold the [STOP] button for longer than 5 seconds. INITIALIZE appears on the display and all settings will return to the default values.
  2. Press the [POWER] button, the home theater has now been reset and will power on. Note: Using the RESET function will erase all stored settings. Do not use this unless necessary.
If that fails try Service mode. But I'm confident the first solution is the correct one.
First on the remote with the unit off
try pressing (Mute 1 8 2 Power) This should kick into "Service Mode" Most samsung products use this code I use it alot. Volume up/down to navigate Mute/Menu to change settings
May 07, 2008 | Samsung HT-DS610 System
** sound
Hide the remote from the set for awhile and see if some sanity returns. If that's the case, service or replace the remote. (Check the batteries first...accordianman
Mar 09, 2008 | Sony DAV-SB100 System
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
