Acer Aspire One  PC Notebook Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some area of my LG laptop screen is not working
Anonymous
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 39 Answers
  • Posted on Feb 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Teacher:
Answers
39
Questions
Helped
9201
Points
109
Are those area cracked, or have a stange rainbown color to it or is it just black?
  • Anonymous Feb 09, 2010
    ops i ment to make it a clarification
Lg r405 do not start when press on ac adapter works with 18.5V
Check AC Adapter for voltage output using multi-meter. If Adapter is GOOD, remove battery and try again. Does fan run? Does screen show Flash Screen? Please advise in detail.
My lg 350 screen has lost sensitivity in some areas...how can i solve this issue?
That must be a hardware issue so all you can do basically is to bring your phone to a LG Store to make it work.
Mar 16, 2012 • Cell Phones
2answers
My phone's (LG PRIME) touch screen isn't working.
No. I had a similar problem. Have to have it sent off to be fixed.
HI I have used LG Flatron L1915S computer monitor. When I plug it into my laptop, it blinks showing the laptop desktop for less than a second then goes black. Other monitors works fine when I plug them...
There is often a function monitor key on the laptop, located near the F7 key area, the icon looks like a monitor on|off and is typically in blue. this key is to be used in combination with the Fn key to enable, disable the external monitor or enable both monitors or just the laptop. Press the key combination until your laptop panel lights up while the monitor is plugged in. Now check your extenal monitor refresh rate and resolution slider settings by right clicking on your desktop go to properties / video settings. (please note monitor settings are under advanced). You should see two monitors in there now. use "identify" button so you know which one to work with. on the external monitor settings, decrease (slide left the slider all the way). If you can set the monitor refresh to 60Htz. Lastly take a flashlight and check if you can see a shadow of your screen on the external monitor, if you can that means the backlight is not working and likely needs the inverter replaced. Hope that helps ! Cheers
LG GE50
this is the problem related to the screen please get the screen replaced
Viety touch screen problem
I cannot remember if there are settings for this in the settings, contact the retailer and ask about repair prcoess
1helpful
3answers
Screen is dark and pixalated
If u have warranty means then claim it.................
2answers
LG LS55 LAPTOP DISPLAY SCREEN BLANK/BLACK
I think your laptop might be stuck in SUSPEND mode. Try unplugging the power and removing the battery and waiting five minutes, and then plugging it back in. If this does not work, try holding down the power button for ten seconds at a time and rebooting.
Good Luck...
LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
