Question about Intel Motherboard
Processor up grade
I saw the page you referred me to but I didn't see my AA# in the section for the 550E thru 850mhz processors. You're sure my motherboard will support a 800mhz processor? Thanks for your help
  • Intel Master
  • 19,396 Answers
Hi yes it was the factory page
Posted on Feb 23, 2008
  • 1 more comment
  • Ginko
    Ginko Feb 23, 2008
    I post it again here
  • Ginko
    Ginko Feb 23, 2008
    The only thing is that you may have to update the bios first
  • Ginko
    Ginko Feb 23, 2008
    You need to have the motherboard running with a cd or a floppy. you boot from cd/floppy with a media you recorded/burned using the bios update that you download from factory here.
    It is not a difficult operation, but if for any case it fails (eg.bad media ) then you risk to fry your MB.
    Bios update procedures may vary. follow the instructions.
    regards
Kitchenaid food processor KFP1642MS This model requires the bowl, lid and plunger to be installed before it works. With all items installed this processor has been intermittent and getting worse.
The solution is 90% going to be replace the lid, or replace the bowl or if you are very unlucky replace both. A proper KitchenAid service agent should have both parts on the shelf and will be able to try a new one of either to see where the fault lies. I think over the years I've replaced more lids than I have bowls.
Feb 25, 2018 | KitchenAid Food Processors
How do I get to the processor on a Compaq EVo N1020v Laptop?
Here is a link to your manual. What you want is addressed on pages 5-28 and 5-29. It will refer you to at least 3 other sections in the manual for accessing the processor. http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00089939
Feb 08, 2015 | Compaq Evo N1020V PC Notebook
Blackout in Motherboard, what is the problem
1) Not trying to sound like 'Mr.Negative' here, but even a new Power Supply can be bad. Happens.
2) http://ee.gigabyte.com/products/page/mb/ga-8gem667k/
I see Electrolytic Capacitors all over that motherboard.
(Radial Aluminum Electrolytic Capacitors to be more specific)
Leads me to the following;
If you have tested the three main voltages coming out of the Power Supply, 3.3 Volts (DC), 5 Volts (DC), and 12 Volts (DC), and know the Power Supply is good, take a look at the capacitors on the motherboard.
Look at the one's immediately surrounding the Processor socket.
THESE are used in the motherboard voltage regulator circuit, for the Processor.
They are NOT the only ones, used in the motherboard voltage regulator circuit, and specifically referring to the one's for the Processor.
There are others not close to the Processor socket, that are also used. (For voltage regulation for the Processor)
What am I 'talking' about?
A Processor has to have a steady, 'clean', supply of Voltage.
It MUST also be kept in the voltage range for the Processor.
Cannot have too much, or too little voltage.
More on the motherboard voltage regulator circuit,
http://www.hardwaresecrets.com/article/616
Upon reading the article it will detail how to find all of the capacitors, that deal with voltage regulation for the Processor. You have to follow the circuit traces on the motherboard.
Visual identification of bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
{NOTE* Sometimes the Electrolytic Paste inside the capacitor dries up, and the capacitor shows no outward visual signs of failure ]
Find some bad Radial Aluminum Electrolytic Capacitors?
Identifying manufacturer, and codes, for values,
http://www.hardwaresecrets.com/article/How-to-Identify-Japanese-Electrolytic-Capacitors/595
One place I recommend to buy Radial Aluminum Electrolytic Capacitors,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw/
[In the fields;
A) Manufacturer: Leave alone
B) Lead Style: Leave alone.
C) Capacitance: Click on the value you need.
D) Tolerance: Leave alone
E) Voltage Rating: Click on the value you need
F) Operating Temperature Range: Leave alone.
G) Termination Style: Radial
H) Dimensions: Leave alone. In the examples in the chart that will come up, you can find the Outer Diameter, and Length you need.
I) Product: Computer Grade Electrolytic Capacitors, but you may want to leave alone. All the capacitors that will be listed in the chart, ARE computer grade, at least.
Now click on -> Apply Filters <- stated under the fields to the Right.
Scroll the page down.
{ Remember these capacitors are rated in MicroFarads. -> uf, not PicoFarads, ->pf. Scroll it down }
Also, hope whoever had the motherboard before you, knew about Anti-Static Precautions. You have been following them, right?
Processor also has fresh, new thermal paste on it? Heatsink is seated tightly, and level on Processor?
The 4-pin ATX +12 Volt power cable is plugged in?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 15, 2012 | Gigabyte GA-8GEM667K Motherboard
My hp pavillion dv7-3079wm shuts off after startup
If you saw that kind of damage, the temperature rose to critical levels in the processor ic causing thermal runner way. Remove the old thermal grease with rubbing alcohol and a paper towel, clean the processor until spotless and the heatsink that mates with it, use high grade thermal grease for computers and a apply a thin coat to both pieces and assemble, make sure any dust or dirt is removed and not blocking vents, compressed air is great for this. If you are very lucky the chip has remained intact, processors are very robust.
Mar 25, 2012 | HP Pavillion dv9740us Notebook
I didn't get a maual really need one.
You can download the manual here:
http://www.managemylife.com/mmh/owner_manuals/70138/Black-Decker-Food-Processor-FP1300-1400Series791
Look carefully upper left of the page where it says click here to download.
This is the link I got from there:
http://www.managemylife.com/manuals/non_lis_pdf/OWNM/FP1300-1400Series791.pdf
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Black & Decker FP1300 Quick N Easy Food...
Amd duron 850mhz
It's a good processor but old enough. The introduction date was Jan-2001 and the price at introduction $149. For todays programs is a bit old. Why do you want to go for a processor like that?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | AMD Duron , 850 MHz Processor
Can i upgrade my processsor from 850mhz to about 1.2ghz
It entirely on your motherboard. If you still have your manual, it will tell you what the fasted supported processor that will work.
If you open your case, you will be able to see the make and model of you motherboard. The manufacturer will be able to inform you of the fastest possible processor.
I hope this helps.
Aug 21, 2009 | Dell PROCESSOR PIII-850MHZ LATITUDE C600...
Up grade for processor
you can only upgrade cpu with the socket you have, which is 478/479, the best you can do the Intel 1.6Mhz M processor 725
if you want a faster CPU, you need to get a new motherboard.
Oct 30, 2008 | Gateway MX3215 Notebook
Which frequency of processor for QDI motherboard BrillianX-1S with BIOS 4.51 PG
hey there.
If you are planning to upgrade the processor with the latest one then it is not possible without upgrading your motherboard.
Because as per all the bus and system configuration requirement with ur CPU you must give the recommended bus speed, bus lines, Address lines, Ram supportive slot, and RAM Frequency.
Your motherboard must suuport all those requirement if you are upgrading ur Processor.
You are right that ur motherboard can only work with PIII CPU.
Upgrade ur motherboard with atleast of 845,945G Chipset to support up to core2 Duo Processor in Intel. OR with A8V-VM and above in Asus Motherboard.
(Gimme your acknowledge by rating me)
Romy
Aug 03, 2008 | Computers & Internet
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
