Nokia N95 Cellular Phone Logo
Anonymous Posted on Feb 09, 2010
My nokia n95 screen goes on but freezes all the time and i always get a black screen. the fone is still on but the screen is just black it only comes on when i put the fone into music mode ( when i slide the fone down) if i slide it back up then the screen goes black again)
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1299
Points
7
Your cellphone is fine. Its the strip which needs to be replaced.
actually the strip connects the LCD and the navigation keys.
U might have noticed sometimes your navigation keys also don't work.
get your strip replaced n your cellphone will be fine again.
slide up the phone and you will see 2 screws at the top.
get these screws removed and replace the strip and also do change these screws after the repairing.
2helpful
2answers
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
1helpful
Screensaver not working
just go in setting there will b optin of screen saver click it then you should click on the screen saver it will b on..
I have a nokia 5300 and all of a sudden when i turn on the phone the screen freezes and shuts off and turns back on but i can't get to my messages or anything that is saved on the phone. If i talk on the...
Hi there.. I believe that you are one of those very active and busy type people who are always on the move. The general reason I believe that you fone is behaving this way is because you do not allow your fone to charge properly, therefore limiting the lifespan of the battery.
My advice: -try and drain you battery dead until you are unable to turn it on at all.
- secondly,charge your fone till it says fully charged.
-thirdly, when using your fone you can either 1). repeat the previous steps and this time drain it by playin music or 2). try using it with caution..
-lastly, next time you decide to charge your fone make sure it is dead/off till you charge it.It should last you a good 2days if all goes well.
These steps can help you prolong the life of your battery and save you $50 to buy a new one..
2answers
Power up problem
this is may be manufracturing defect and may need repair assistance
2answers
Having problems with my phone
just press *#7370# and put ur code 12345 and ur phone will b ok but remove ur memory card
Nokia n95
looks like your battery connecters are damaged.
Take it to a phone shop and do not mess with it as it can cause more damage.
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
