The solution is here, The condensor container under the dryer fan is block, you have to remove it and clean it, if you are not technical ask someone else to clean it, beacuse you have to open lots of screw and remove the dryer fan/heater to get to the condenser container.by ericlimtf
Check for blocked air flow to your outside vent on the outside of your home.
Most of the cases it’s the dryer vent. Check if it is plugged properly which causes no heating up properly. Sometimes new dryers have a lot more sensors on them and it’s very sensitive about needing a clean vent to let out the heat. A dirty vent would build up of lent in it. This causes the dryer to not vent properly and it would keep shutting the flame off. Blow it out and it should heat up and dries quickly. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.:-
Vent:------
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.---
Heating element:-----
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.------
Cycling thermostat:-------
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.--------
This
will help. Thanks please keep updated.please do rate
the solution positively .thank you for using fixya
For starters this is a combo. NO VENTS OUTSIDE of THE HOUSE, please read my question carefully make sure you know the make I am talking of, then reply, Thank you, Robert
Hi, could you please describe where the vent on this model may be blocked, as I assume your not talking about a vent outlet hose that goes from the dryer to the wall or ceiling as on other models, this vent is clear from the back hose of the tank or drum up to the condenser, it is also clear from the fan to the top of the door boor seal. Thanks Robert
I'll await your reply to my last email, Thanks Robert.
I am wanting some specific clues to my first question, please read my first question carefully as to what I have already tested, then respond to my situation regarding this specific model, Thanks. Robert.
