Question about JVC AV-65WP55 65" Rear Projection HDTV-Ready Television
65 in.JVC bad picture
Picture has green tint color drooping down from corner to corner at the top of screen.Allso has green going across the bottom PLEASE HELP!!!!!!!
  • ampowell Dec 28, 2008
    Did you get your problem fixed? If so what was the problem and the cost to fix it - just an approximate cost.
    Thanks,
    AMP
  • 549 Answers
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Posted on Feb 22, 2008
The top left of the screen is drooping down and is green,red goes across where green is drooping from.
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 28, 2011 | Hitachi 46F500 46" Rear Projection...
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Screen is bowed (top and bottom) Color has a green and purple tint?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example video
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Jan 15, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art. 65" projection TV. AV-65WP74 green screen sages real low.
you have bad convergence ic and or resistors
this repair usually requires a repair tech
Nov 12, 2007 | JVC AV-56WP30 56" Rear Projection...
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
JVC AV-65WP55 65" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
