Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
THe supposed "self cleaning" filter
THe supposed "self cleaning" filter is comptetely clogged. Are we doing something wrong? also, the wand attachment doesnt suck like we'd like it too.
  • 126 Answers
That filter is coated with a telfon coating and will only "self clean" to a point. You will have to remove it periodiaclly and tap it gently to dislodge dirt from the element. You should also check the secondary filter located under the dirt cup. It is visible through the hole that the filter sits on top of. This filter is washable as is the main cartridge filter. It's important that they are completely dry before installing.
The hose on this machine is very limited in how much suction it will provide. It is activated by a valve in the base that opens and closes with the handle. When the handle is positioned in the upright position, the valve closes off the front roller suction and diverts it to the hose. These valves are very limited in how well they seal and you normally don't get the full benefit of the suction that the motor actually produces. This is further compounded by debris collecting in the valve and not allowing it to close fully and hence, it will leak. It's just the nature of the beast.
Keep the filters clean and the hose and the floor function will work much better.
Posted on Feb 22, 2008
Using the wand stuff shoots out of the vacuum?
Hi there! It sounds like you may have a clog in your vacuum. Try these steps.
1. Remove the hose from both ends.
2. Use a broom stick or something similar to loosen and remove any clogs from the hose.
3. Remove the hood or bottom plate to access the brush-roll.
4. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
5. Clean all filters as your manual suggests. Replace them if necessary.
Hope this was helpful!
Jul 20, 2014 | Hoover Vacuums
Centralux
Low suction is either a clogged pipeline (very rare), a broken or open inlet valve in the system, a clogged hose or wand system, a clogged washable filter, the small screen behind the filter when removed needs cleaned, or the motor itself. Would need more detailed info. to pinpoint but hope it helped!
May 31, 2014 | Electrolux Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Clogged Sebo automatic X-1 vacuum
Hi There,
So when this light is displaying, it's says "Bag Full or Clog" on the indicator. If you have changed the bag, and it's still showing this light, it means that you either have a clog in the vacuum, or your filters are dirty, which is reducing the suction and making the machine think that your bag is full. If your machine is actually cutting off, this indicates that your machine is definitely clogged, or something is stuck inside which is causing the motor to not get air flow, and cauing the machine to over heat. When it shuts off like this, it's a protection system that prevents any damage from happening to the motor when it can't breathe and starts to overheat.
My guess is that there is probably a clog in the machine somewhere, or the filters are dirty. Here's what you may do to diagnosis the machine, and try to isolate the clog to find out where it is in the vacuum.
Step 1. Remove the hose and wand assembly from the vacuum cleaner completely. You may do this by pressing the two tabs on the end of the hose that plugs into the vacuum cleaner:
With the hose and the wand removed from the vacuum, it should look like this:
Step 2. Now turn the vacuum cleaner on and check to see if the red light comes on while the hose and the wand have been removed. If the light comes on, then this indicates that your filter is dirty (or the PCB electric board is bad if the filter is clean) and needs to be replaced.
Step 2. Re-attach the hose and wand back on the vacuum, but just the end of the hose that goes into the vacuum cleaner, leave the wand out of the vacuum cleaner so it looks like this:
Turn the machine on now as if you were using the attachment hose to clean corners or above the floor and see if the red light comes on here. Also listen to the noise the motor makes and see if the noise changes when you put the hose back on the vacuum cleaner. If the red light appears, or if the motor makes a higher pitched noise now, then this indicates that you have a clog in your hose or wand. You may verify this by remove the hose again from the vacuum, and also removing the wand from the hose by pressing the hose release button on the wand and pulling the hose out of the wand. Look down both of the parts and see if you can see thru both sides. If you're not able to see light through the hose, or the wand, this indicates this is where the clog is. You may take a metal clothes hanger, and try removing the clog this way.
Step 3. If the red light did not display with the wand not inserted into the vacuum, put the wand back into the vacuum cleaner as if you were vacuuming the floors:
Turn the machine on, and see if the red light comes on in this position. If the light does come on, then this indicates that you have a clog in the bottom of the vacuum cleaner. To check and see the clog in the bottom of the machine, I find it easiest to remove the upper bag housing from the vacuum cleaner completely so you're just looking at the bottom power nozzle of the vacuum cleaner. There's a button at the bottom of the machine that is either a grey, or yellow color depending on what color your vacuum is. Simply press this button in, and lift upwards on the handle or the bag housing at the same time:
Step 4. After the bag housing has been removed, turn the lower part of the vacuum upside down so the brushes are facing upwards. There's a little orange flap on the bottom of the machine that is actually a clog port. Almost every time there is a clog in a Sebo, this is where I typically find the clog. Open up this orange colored trap door, and look to see if you can see any obstruction or clog underneath of here:
Step 5. You may rotate the neck of the power nozzle part towards you so that you may look inside to see if you see any obstructions inside:
Step 5. You may also remove the brushes from the vacuum and look behind the brushes at the suction port, or the area where the suction goes through the vacuum to see if you see anything obstructing the suction here.
These are really the only places that the Sebo can get clogged. If you checked all of these areas, and the red light is still displaying, this means that your PC Board that controls this indicator has gone bad, and needs to be replaced. If this is the case, please just reply to this repair using the comment field, and I'll be more then happy to help you through the replacement of replacing the PCB Board.
I hope this answer was helpful to you, and you were able to find the clog and fix the problem. If you found my repair helpful, please be sure to rate the repair by clicking the 4 thumbs up icons in the top right hand corner, or by leaving feedback for me. This is really what keeps repair professionals continue to post free repair solutions rather then just the paid questions. It's really appreciated when you take the time and do this if the repair was helpful.
Thank you so much,
Jan 29, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Red light on then cuts out how do i unblock please? lost the manual.
Hi There,.
Aug 09, 2012 | Sebo X4 Bagged Upright Vacuum
My filter queen majestic quit working. I opened up the unit to see what was wrong and I did not immediately notice anything wrong. Upon furter examination I noticed one of the traces on the printed circuit...
I recommend replacing the card. Soldering involves the risk of further damaging the card, so it would be useless anyway. Why waste valuable time?
There is a possibility of the motor overheating, generally due to a blockage in the airflow system somewhere. Check all filters, hose, wands, and power nozzle for dirt and/or clogs.
Check wiring connections, including hose to wands to power nozzle. Check all switches.
It sounds like you know how to do this, but if you have any questions, repost.
Jan 03, 2011 | Filter Queen Majestic Canister Vacuum
Very little suction only in the wand
It's cloggeThread something tjhru the wand and it cleans out easily. For the rest of the vacuum, make sure there's a clean bag in it. Snd you may have to unscrew the beater bar part. It can get clogged easily especially if you vacuum damp things up!
Dec 02, 2010 | Vacuums
No suction in the wand and the vacuum shuts off in the upright position. Just bought a new filter
the wand is clogged. shuttimg off sounds weird. but maybe your cord or something is hitting the off switch.
Sep 05, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The wand has no suction
There's a clog somewhere then - probably at the end of the hose which means you should take off the hose at the bottom by the cord clip and have a look. Also check all inspection air ways to ensure there are no clogs. Usually if there's no suction through the handle a tell tale sign is that something has either got stuck or there's a tear in the hose. Hope that helps.
Feb 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Clogged hepa filter
If the hepa filter is clogged chances are it is not turning like it is supposed to. Hoover apperantly has a terrible R&D department because this is a bad unit. The filter is supposed to be self cleaning because it spins and a little tab is supposed to knock out dirt but does a crappy job of that. The transmission is what spins the filter and this must be replaced. If in warranty take it to your local Best Buy for service.
Dec 15, 2008 | Hoover U8361-900 WindTunnel 2 Bagless...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
48 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
