Question about Gateway (6000598) Modem
Modems with rotors
Model speedstream 2701HG-is there a router in this modem
    Problem Solver:
  • 12 Answers
Actually, I believe that's a 2-wire 2701HG DSL modem you're referring to, possibly rebranded as a Speedstream. If so, then the answer is yes, there's a router in it.
Posted on Feb 25, 2008
How do I configure for wireless?
Siemens Speedstream 4100 is just a modem, if you want to connect to the internet wireless you will need to set up your speedstream modem with a wireless router.
It can work with almost all the wireless routers available in the market, but I would recommend a Linksys wireless router.
Dec 31, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Am trying to find out if can use a router with speedstream 5100 Part # 060-E142-A02(modem access code 2038304758?
Yes you can. Connect the ethernet cable (circled in the image below) from your speedstream modem to the Lan port on your router. Hope this helps. 1c801d4.gif
Jun 24, 2010 | Efficient Networks SpeedStream 5100 Modem
What is default password for 2701hg-b modem?
normally its : password:
sometimes it is printed on the bottom lable on the router will be something like....
user = admin
password = password
see how you go
Feb 13, 2010 | 2wire 2700HG-B Router (2700HGB)
Siemens Speedstream 4100: Enabling ports for Xbox live play
Do you have a router connected between modem and console? The speedstream itself has no port blocking. if it is a straight line between modem and console then all ports are already open, but chances are you have a router between the too, especially if you have other devices connected(computers and the like). If that is the case, then it is the router in which you need to open the ports. If you do have one, post make and model plus version number if applicable.
Jul 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream router 2623 doesn't work
it could be possible that the router is just not in sync with the modem. you can try to power cycle the devices first by turning them off. then turn on your modem first, wait for all the necessary lights to turn on, then the router and then the computers. check if you'll be able to connect to the internet again. if not, you may need to access the router's page to check if it's properly configured or not.
hope this'll help you and just ask me if you'll have other concern
ciao!
Jul 10, 2008 | Siemens SpeedStream 2624 Router...
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Aug 27, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream 2604 Router linking issue
It sounds like you are using a straight-through network cable. Try using a cross-over network cable to connect the your computer to the SpeedStream. One can be purchased for pretty cheap money from any consumer electronics store.
Oct 04, 2006 | Siemens SpeedStream 2604 Router (obss2604...
Gateway (6000598) Modem Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
