Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
U5780-900 Windtunnel maintance / cleaning
What is the best way to clean the bagless dirt trap when it gets really dirty?
  • 552 Answers
Http://www.hoover.com/pdfs/manuals/U5780900.pdf
Here is a link to a pdf file at hoover website.
It explains alot.
Posted on Feb 22, 2008
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
When i vacuum the dirt and particles are not going into the windtunnel container-appears to be cleaning floor but isnt making it into the container.filters are checked and cleaned.less than 6 months old
If there is no obvious clog in the unit, you might want to check the beater brush and the drive belt. Be sure the belt is not broken and be sure the beater brush is free enough to rotate. If there is a broken belt it will be obvious.
I suggest you remove the beater brush and clean it as best you can, add some WD40 at each end by the brush holders and reassemble.
I would appreciate a Thumbs Up rating on this if you find my solution to be beneficial.
Oct 05, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
How can i clean the inside of my bagless vacuum
If you mean how to clean the dirt containers, rinse them out with water and let them dry before reassembly. Many bagless vacs also have foam filters which can be cleaned the same way. Good luck.
Mar 21, 2010 | Hoover U5753-900 WindTunnel Bagless...
Vacuum is spitting dirt and debris out the back--what can I do?
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing.
check the hoes for dirt that might stick up.if the problem continues it needs a service.
Jul 30, 2009 | Hoover U5753-900 WindTunnel Bagless...
My Hoover Windtunnel, 12-amp, UGG16-900 (or U6616-900 - hard to make out the "G"s from the "6"s) suddenly lost suction this morning. The dirt collection thing is completely clean (I always clean it out...
usually on this machine the door/valve assembly is to blame. if something gets caught in the door/valve assembly it can break this part. you can take it in to see what the est. would be. hope this helps
Jul 27, 2009 | Hoover U6630-900 WindTunnel Bagless...
My self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cleaning my bagless vacuum
Hi Anne,
It does not say to get the filter wet but;;;;;;;;;;;;;;;;; I have had mine for 2 years. When I do a thourgh cleaning of the filter. I actually fill the inside of the filter up with water then hose the outside and let air dry. Another great thing to do is always have 2 filters. Let the one dry out and pop in a new one.
Good luck...
I have only had 2 filters.. and they clean out great with water..
Deb
Nov 17, 2008 | Hoover U6630-900 WindTunnel Bagless...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
550 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
