Question about RCA DISH Network(r) 311 Satellite System
Only picking up one satellite
Hi, I have just Installed a new satellite in my Rv and my dish is on a tripod. I am only picking up sat 110 when checking my switch connections and I am picking up only half the channels. Could the problem be my dish alignment or the new receiver?
  • 1 more comment
  • Johnboy33 Feb 23, 2008
    Hi Jaime thanks for responding. The receiver is hooked up to a dish 500 and believe it is a dual lnb.
    Thanks Jaime, the receiver is a 311 that I purchuesd from camping world. Currently I am only picking Sat 110 at 72 % .Will work on the alingment today as I have some time finnaly
  • Jaime Hernandez May 11, 2010
    What type of dish do you have?
    How many LNBs do you have on your dish?
  • 2,336 Answers
Thank you for the info.
Here is what you can try:
Try to get the Echo 8.10(110W) first by connecting the LNB on your left if you are behind the dish. On the first transponder from 110W you need to get anything better than 90% quality.
After this is done you may have to play with the skew until you get 119W. On 119W the first transponder frequency is 12239Mhz.
The skew will depend on where you live.
Check here for more info on the parameters to get your dish align.
BTW, What kind of receiver do you have?
Posted on Feb 23, 2008
Can I as subscriber to direct tv can I use a mobile satellite dish
DIRECTV FOR TRAVELERS
https://www.directv.com/DTVAPP/content/contentPage.jsp?assetId=P6730097
With DIRECTV's cutting-edge mobile service, you can enjoy your favorite TV ... Contact one of the following distributors to order your mobile satellite receiver and ...
How to SetUp Your DirecTV On the Road in Your RV ' Roadtreking Blog
roadtreking.com/how-to-take-directv-on-road/ Jun 20, 2013 - Learn how easily you can set up DirectTV in your RV. ... You also have a permanently installed satellite dish at your house, probably ... The trick to making your system portable is to bring the box and a second dish on a tripod, ... First, set up your tripod so the mast is perpendicular - use a torpedo level for ...
A Guide to RV Antennas for Satellite Internet & TV - Reviews.org
www.reviews.org/internet-service/rv-satellite-internet-and-tv-antennas/ Getting satellite internet and TV on your RV isn't as hard as you may think. ... DISH and DIRECTV do not actually offer an antenna (dish) that can be used on the ... a proprietary dish for your mobile internet unless you pair DIRECTV with an ...
How to Set Up a Portable DirecTV Satellite Dish ' eBay
www.ebay.com/gds/How-to-Set-Up-a-Portable-DirecTV-Satellite-Dish-/.../g.html Before obtaining a portable DirecTV satellite dish, purchase a subscription. Subscribers who already have DirecTV installed at a residence can use a part-time ...
direct tv can use mobile satellite dish Google Search
Sep 25, 2017 | Televison & Video
Dish 625 with legacy lnb
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Mar 31, 2012 | DISH Network DVR-625 DTV Receiver /...
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
Can't get Dish500 satellite system set-up
If you tripod or mount is perfectly plumb and you have the correct information for the settings at your current location then you may have a faulty piece of hardware ensure all connections are tight and that all bolts on the dish are tight. Once you get 119 try gently pulling on the top of the dish and see if that increases the signal stregth and gets you 110 since it is at a higher elevation than 119. let me know if this helps.
Thanks for using Fix Ya.
Dec 03, 2009 | DISH Network ViP 211 DTV Receiver
No signal on one tuner for dual tuner box.. neither tv works.
Hi benray there is something else youcan do on that to make sure your getting the strongest signal possible. Youwill need to press the MENU-6-1-1 buttons on the remote. Select Check Switchand Test, after the test is complete select done and then check the signal andif there is still a weak signal we will need to re-point the Dish.
Oct 24, 2009 | DISH Network 322 DTV Receiver
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
No local channels
your locals may be broadcasted on a a different satellite (directv uses 7 different ones). when u travel, your dish on your rv might be capable of receiving the satellite that broadcasts normal programming. the dish on your home may look a little different and picks up more than one of the satellite signals. also these satellites are in different locations
Oct 23, 2008 | Philips DIRECTV H20 DTV Receiver
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Oct 18, 2007 | RCA DISH Network(r) 311 Satellite System
Televison & Video Logo
395 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
