Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS55513 When I turn on the tv there is a message at the bottom of the screen that reads digital link for cable V and TV Audio cannot be established. TV will work great for about 10 minutes then the screen goes black. Is the problem with the cable box or the TV?
  • slasko Mar 15, 2008
    i need to find replacement sreens, clear cover, and diffuser scren, ant ides where to get them?
    slasko_53@netzero.com
Misubishi, ws55513, clear screen cover, diffuser screen, need some leads as to where to get them
Posted on Mar 15, 2008
  • slasko Mar 16, 2008
    hi,
    i need to find both screens(clear, and diffuser) for a misubishi ws 55513 rear projection screnn hdtv.
    any help out there
How do I hook cable up to my ws-55513
The manual (available here):
http://www.searspartsdirect.com/partsdirect/user-manuals/WS55513-mitsubishi-parts-TV-manual
says to connect to ANT-DTV if it's cable for digital broadcast
Nov 10, 2014 | Televison & Video
Mitsubishi ws-65313 always says tv will turn off in 2 minutes, how do you stop this
It may be the reason they got rid of it but the set should have a hidden menu called Option which will allow a hard reset of the entire set and should cure the quirk the set seems to have==going to need and have the Mitsubishi remote and a four digit number code to do it.
Aug 27, 2012 | Mitsubishi WS-65313 65" Rear Projection...
Im trying to hook my insignia flat screan tv to my mitsubishi M-VR900 recevier the tv has plug for audio out and recevier has a tv audio in red/whit plug and i have 2 speakers i have on the front spearker...
Go into the onscreen menu of your TV, find and select the audio options. Make sure the audio out on the TV is enabled (this might be an automatic feature and might not be displayed -it depends on your TV model). Next make sure your receiver is working and (if it is so equipped) make sure your speaker switch is enabled.
Make sure all of your cables are working. You can do this by switching out the cables one at a time for ones you know are good.
Make sure no headphones are plugged into your receiver or the TV -this usually turns off your audio signal to any speakers.
Your TV remote may be equipped to control the volume output of the external audio out signal. Some TVs automatically turn off the internal speakers when you hookup or select an external audio output. turn up the volume on both (your TV and the Mitsubishi).
Does the Mitsubishi work on other sources (DVD, radio etc...)?
Remember to double check your cable connections -audio OUT from the TV to audio IN into the Mitsubishi. Reversed connections can damage your TV and amplifier electronics.
What model is your Insignia? Some are equipped with digital outputs which, if your receiver is so equipped as well, can send surround sound (home theatre) signals to your receiver. These can be orange-colored rca jacks or optical jacks. They do not send analog audio signals.
Once all the cables are double-checked, (double-check your speaker connections!), turn on your receiver, TV and signal source (cable, satellite DVD etc...), bring the volume control (both on the Mitsubishi and the TV) up to nominal levels. You should hear sound.
One more thing:
Make sure your speakers work. You can try them on another amp or simply touch the speaker terminals with a 9-volt battery (the speakers should move in or out depending on the 'phase' of the connection).
Hope that helps.
Nov 26, 2011 | Audio Players & Recorders
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
WS55513 image permanently burnt in
Need a complete set of CRTs we would do it for $120 for each one -Installed
Jan 02, 2010 | Mitsubishi WS-55513 55" Rear Projection...
DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
Sep 22, 2009 | LG 32LH20 32 in. LCD HDTV
Code says check connections or power. RGBHV or YPrPb may be inval
Dunno. But if the tv has been 'reset' you will need to re-assign all devices (via NetCommand). Also complete the setup again to verify audio & video selections. If you can select "video" on the remote, you should see various video options...including brightness, etc. If OK...you need to get the right device assigned to the TV for viewing from cable box.
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS55513 480i Signal no Color
That may be a TV problem but can also be a Cable box problem.Do you have any other 480i signals hooked to the TV?
Also most Comcast HD boxes can be set to output SD signals at 480p which may solve the problem. Usually get to the setting by turning the cable box off and pressing menu on the box, not remote.
It should display a different menu on the tv screen, arrow down to 4X3 overide then arrow right and try 480p.
Feb 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Mitsubishi WS55513 tv
capacitor problem.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 14, 2007 | Televison & Video
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
