Logitech Harmony 550 Remote Control Logo
Posted on Feb 09, 2010
The contrast is bad on my 610 harmony. how do i
The contrast is bad on my 610 harmony. how do i increase it
A
Anonymous
You can't, unfortunately. I would try upgrading the firmware on the remote. If that doesnt fix it then it may have to be replaced.
To update the firmware:
1. Log into the software
2. Click 'Downloads' at the top
3. Click 'Firmware'
4. Update the remote
1helpful
How to adjust contrast on dell 610
From this web site:
http://www.computerhope.com/issues/ch000594.htm
How do I adjust my brightness or contrast on my laptop? Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
Other examples also shown in the above picture include pressing Fn and F1 and F2 or F7 and F8 to increase and decrease the brightness. If none of the above examples resemble your keyboard look for keys on the keyboard that have pictures of a sun or a half moon to identify the correct key to adjust the brightness.
How can I adjust the laptop contrast? Laptops only allow users to adjust the brightness of their screen. Contrast settings are not adjustable on a laptop display.
How do I save the new adjusted settings? After adjusting your laptops brightness it will retain the new settings.
Laptop brightness is still not enough or screen is black If after following the above steps your brightness is still not enough, plug your laptop into the wall to make sure it is not a power setting that is decreasing the brightness. If the laptop is plugged in but still is not bright enough, try the suggestions on the below link.
5helpful
A Logitech Harmony 610 model universal remote control
Hi. I sure do know how to fix this! haha. Usually just taking the battery out for about a minute then putting it back in works, but if not it will get out of safe mode if you update the firmware.
1, Log in to the software.
3. Click 'Firmware'
My volume won't increase on my LCD tv. What can I
I can help you reprogram your Logitech Harmony 520 remote for your LCD TV.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
2helpful
3answers
How can I adjust the contrast on my laptop, I can't see very well
Hold the Fn key down, then press the Right Side Arrow key to increase brightness. (Bottom of keyboard, 5th key from the right)
Granted, that doesn't increase the contrast, it increases the Brightness.
Should the brightness not increase to a level that you feel is comfortable, then I suggest you have a Backlight, or Inverter going bad.
3helpful
The screen is not working
Contrast may be too light or too high.
Press [CLEAR] key and adjust contrast (Reduce or increase)
Reduce the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Adjust screen Contrast
<Fn> +
Contrast up Increases the screen Contrast
<Fn> +
Contrast
down
Decreases the screen Contrast.
This will help you achieve this adjustment.
1helpful
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Increase or decrease of contrast
Rammohannnnn........wake up!!!
Try the same processed again like last time go to contrast, this time press the + buttons to increased the contrast to the desired setting. Have a nice day!
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
