Freeze up While watching tv one night I tried to adjust volume. The volume bar displayed...nothing happened. I tried to change channels...nothing happened. I tried to turn off tv....nothing happened. Then I went to tv and tried all the push buttons on tv.....nothing happened----I ended up unplugging tv then replugging it in and it seemed to work fine. What happened? The tv was still broadcasting but no response from remote or tv push buttons?
  • 1 more comment
  • ggm1 Feb 27, 2008
    In our case, while changing the channels the system froze on a specific channel, with the channel display staying visible, which usually goes away after few seconds. The system still responded to volume changes and input changes, but the you could not change the channel, by entering a channel, or using the up/down arrows. Home menu button is also not responding. Basically most buttons do not. The buttons on the side of the TV also behave in the same manner. If we turn off the TV and turn it back on we can get to Home Menu, but the Tuner never initializes, unless you completely unplug the TV. Does anyone know where this eprom is located. Is it inside the TV or inside the receiver.
  • Anonymous May 03, 2008
    TV works fine. Then 10 minutes into watching sound goes silent. Nothing will adjust. Channels will not change. Volume will not adjust. TV is locked on that channel with no volume. The only recourse is to unplug and replug. After that, the TV works fine until this happens again. It may not happen again for the remainder of the day. It usually takes place within the first 30 minutes of viewing. After the unplug, replug experience the set works fine.
  • Anonymous Mar 13, 2009
    input and channel dont work on the TV and the remote.....
    President:
  • 1,779 Answers
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Posted on Feb 22, 2008
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
At random a black retangular box appears on the screen
Go into the TV's closed-caption settings and turn off captioning. You'll find it's set for "text" mode right now. What's happening is that in text mode, the set blanks out the part of the screen where the text will go but there isn't any. On channels or programs where captions aren't being broadcast you don't see anything. With the captions turned off the box will go away.
Apr 10, 2009 | Toshiba 20AF41 20" TV
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
Jul 17, 2007 | Insignia IS 20" TV040919 TV
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Televison & Video Logo
270 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
