Question about SanDisk Sansa e250 MP3 Player
Can't transfer data files
I'm trying to transfer files from our library (books on CD) and I'm getting the following error message:
error message "Unable to transfer the selected title because Insert 3 returned 0xC00D2772"
I used to be able to do it with no problem.
  • 6 more comments
  • NurseFarmer Mar 27, 2008
    I have recently had the same problem after months of no problems.
    I get the same error [insert 3] Unable to transfer and returned 0xC00D2772.
    I have reinstalled Overdrive, I have reinstalled Windows Media 10, I have updated the Media on the toolbar in Overdrive. I have redownloaded my library audio files. I have tried MTP and also MSC. Nothing has worked so far.
  • Rapunzzelle Apr 10, 2008
    I have received the same error here and there. At other times, the progress bar just sits there. I haven't been able to transfer files for over a month so I have been using my other computer. Very inconvienent but I'm at a loss. I too have re-installed Overdrive Media and Media player.
  • Lynn Bailey Apr 22, 2008
    yup. Looks like something has been changed because I have listened to tons of books on tape on my sansa from overdrive media. All of a sudden, poof, nothing. It acts as if you no longer have rights to play the files.
    I haven't re-installed everything, but I did make sure that the msc mtp settings were switched back and forth, and I made sure that I did not have an overly full player. I called the library, but of course they know nothing.
    boydschpsych
  • pelo7 Apr 23, 2008
    i try to put songs in my sansa e250 and it wont let me......it says "error"
  • Anonymous May 04, 2008
    I have alot of memory on my MP3, but when I recorded off the radio, it said I have no memory, and I only recorded 101 songs off the radio. Then, when I tried to download, it wouldn't go in. I tried it about 5 or 7 times and it still wouldn't go into my MP3. Could you help me find a solution to this problem?
  • Anonymous Jun 10, 2008
    I have the exact same" Insert 3 returned 0xC00D2772" error message on my sansa e250 when I now try to transfer audio books to the player. I have used this device with the same audio books service for 2 years and have never had this problem before. I tried switching the USB setting as suggested, but it doesn't work. I also went to the Sansa site and downloaded the latest firmware, I reformatted the device, and I downloaded the last OverDrive Media Console software. Nothing works.
  • seijuni May 11, 2010
    Solution link . . .
    http://www.Sansae250MP3Player.com
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    What are you using to do the transfer? It sure doesn't sound like a Windows Explorer error, and I bet you could still transfer a directory full of Books-on-Tape mp3s to the MUSIC directory; is there anything else to the error box like a window title or something?
    By the way: Supposedly there is a directory corruption thing that can happen to Flash devices from time to time, curable with a Lock-Power-on-Record reset of the device (but reel off a backup first, as may be necessary.)
  • 3 Answers
Reaper 22's solution was the first thing of everything that has been posted that actually did work!! Way to go!!
Posted on Aug 13, 2008
I had the same problem went to they sync menu on Windows Media Player 11 went to the arrow at the bottom of the tab to expand the menu there was my sansa 250 I went down to it which expanded the menu to the side from there I selected format clicked which erased anything previous on the player as soon as I was done I was able to tranfer my books to my player as I normally do. Hope this helps
Reaper 22
Posted on Aug 12, 2008
I was having the same problem and I tried all of the suggested solutions but none of them worked. On a different site, someone suggested using the format function on the computer and IT WORKED!!! With the player connected, I went into My Computer. I right clicked on the icon for my player and chose "Format." After it was done, I went to books I had downloaded on OverDrive and transferred one to the e250 w no trouble! Here is a copy of the directions I followed: "Please try to format the player as formatting it will likely correct the issue. Formatting will destroy all data on the player and get rid of any corruption. You would need to right click on the removable disk icon under My Computer and choose format, we recommend using the FAT file system." Hope this works for others. Note that it will erase everything else you have on the player. This Sansa device has been a ton of trouble, but I hate to give up on it because of the money I spent on it. I won't buy another, though.
Posted on Jun 10, 2008
Does your mp3 player play CDAs? Because that is the normal extension for Book CDs on tape, not mp3s. If you convert your
book cda files to mp3 files first, you should have no problem. Does anyone know an itunes like program that will do this simply for my Sandisk model e260 mp3 player? I just did it all by hand and it was hard. I would like it if there was some freeware somewhere that would do it for me. I had to create 8 subdirectories to place them on the Sandisk playlist. It was my first time and it took parts of 2 days.
Mike Rice
mike872@centurytel.net
Posted on Apr 20, 2008
  • jaszmin Aug 14, 2008
    Its me again.  Download CDEX 1.57 or any version really.  CDEX
    is essentially just a converter of file types to and from mp3.  But it
    has an extra quality that will allow you to TAG your files.  Put the
    first CD in your 'puter with CDEX open.  Create a directory anywhere with the name of the book.  Then in options in CDEX pulldown, put that directory as where you want your files to go.  Do it twice because it asks for it twice.  You will find tag areas for author and book name.  Put both in with 1 after each of them.  That's will compel the first disk to play its files first and in the order they are assembled on the CDR.  When its all converted, you take the first CDR out and put in the second.  When you have converted them all, you will find the book neatly packaged all in order.  Drag and drop the original file you created to the
    Sansa Music directory.  Exit CDEX, which incidentally is freeware.  Unhinge your sansa from the 'puter.  Plug in your earphones, get music up and it will play in perfect order.  The one drawback of the sansa is it only has pause as a bookmark.
Hi shellibelli,
I am not expert, but I had the same problem using OverDrive Media to transfer audio books and music to my SanClip 2mb. So, here is what I did, I hope it will help you.
On my mp3 player I went to "Settings" -> "USB Mode" - > and then I selected "MTP", whereas "AutoDetect" was what was previously selected by default. This seemed to solve my problem. I hope it helps you!
Posted on Mar 07, 2008
2 Suggested Answers
SOURCE: Can't transfer data files
I called Sansa and I was instructed to format my player. The steps were as follows:
1)Connect player to computer
2)Go to my computer and right click on your player
3) Click format on the menu
This will start the formatting of the player. After this I was fine. This is the 2nd time I have had to do this in a year and all I put on this player are books.
******Please Note**** This process will erase any files you have on your mp3 player.
Posted on May 15, 2008
Transfer books from laptop library to my new tablet
What kind of new tablet do you use? If it's an iPad, you are able to download books to iPad directly. Just launch iTunes on your tablet and go to iTunes Store, then search for the book you need and click Get below the book cover.
transfer-books-from-laptop-library-new-oxaxc0rwhkhzilrwacqreyis-2-0.png When you want to download ebooks to iPad, you are able to sync the books with iTunes. Having the latest version of iTunes installed on computer, you are able to connect your iPad to computer with USB and sync ebooks to computer.
After getting the ebooks in iTunes library, you are able to sync the books to iPad easily. The following guidance will show you how to finish the task.
1. Plug iPad into computer via USB, and iTunes will launch automatically.
2. Click the iPad icon and choose Books category in the left sidebar.
3. Check Sync Books and choose All Books or Selected Books.
4. Click Sync at the right bottom to start syncing books to iPad.
After syncing books to iPad with iTunes, you will get the books in the iBooks app on iPad. Now you have an enjoyment. But note that you should shut down auto sync before you sync books with iTunes. To shut down auto sync of iTunes, you need to go to Edit > Preferences > Devices on iPad, and check "Prevent iPods, iPhones and iPads from syncing automatically".
If you have downloaded or got books from elsewhere, you can add books to iTunes at first, and then sync these ebooks to iPad. To add ebooks from computer to iTunes library, you only need to click File > Add File to Library at the upper left corner of iTunes, and then the ebooks will be added to iTunes Book Library.
Visit this guide for more methods about how to transfer books to iPad tablet. http://www.leawo.org/tutorial/download-ebooks-to-ipad.html
Apr 10, 2016 | Computers & Internet
Can u tell me the model of ur mp3 player ???
Mar 07, 2008 | Audio Players & Recorders
Overdrive Media audio book transfer to Asus TF101 error code 0x80045011
Did you ever get this working? I'm seeing the same error when trying to transfer an audiobook checked out from the Dallas Public Library to my Samsung Galaxy Nexus phone.
Sep 08, 2012 | OverDrive Media Console
Library books show "protected page"
This error may happen when you have eBooks that you borrowed from the library in both Adobe DRM-protected ePub and PDF formats on the Reader digital book at the same time. Follow these steps to correct this issue:
1. Delete all borrwed books from the Reader digital book.
2. Verify that all borrowed books are in the same format (either ePub or PDF) before transferring them back to your Reader digital book.
eBookBoy
http://digialreader.freeforums.org
Jul 10, 2011 | Sony Reader Touch PRS-600
Can i transfer purchases from any iphone to my itune?
Yes, just plug in the iPhone into the computer via USB that you have the iTunes on and you sync it by clicking "sync" and a message will pop up asking if you want to transfer your purchases to your library and at that point you click "yes".
Mar 24, 2011 | Apple iTunes
I was afraid of that. The file that you are trying to load has a DRM license on it that has a fixed-term license. It will play on your player for about a wekk or so, and then it is unusable except on the computer itself.
Most mp3 players that claim to support audiobooks don't really support most audiobooks - or don't play them correctly. Audiobooks that are in mp3 format (as in, NOT Overdrive) will give you the fewest problems.
Mar 02, 2009 | SanDisk Sansa Clip MP3 Player
Can't transfer data files from data libraby to pc
System files can often be hidden from view. But when transferring a file the computer will see these hidden files even if you can't. Most Windows computers have the option to display hidden files. Find out how to do this and then you will see them.
May 09, 2017 | Dell DJ MP3 Player
May 08, 2008 | RCA JET S2002 MP3 Player
Error code:00007180
I have this problem too. Found that if you go to the folder that has the music file in it, right click on each problem file and select 'open with -> " and choose Sonic stage, then it will import the file. Next problem may be that it imports it with 'unknown' as the file name but if you then right click on the file within SonicStage and select 'Get CD info' it will find it. Tedious if you have several dozen/hundred files that won't import I'm afraid...
Dec 07, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Error message when I try to play a cd,dvd or rip
Before we try blaming a faulty cd/dvd unit lets check out faulty Windows Media Player Software. Is Media Player up to date? Try installing iTunes set as default. That will force the cd/dvd association to iTunes. See if the player works or what the error is...If it works...Then re-open Media player make it the default again and see it what it does. or This is from the Microsoft site: Windows Media Player cannot find the file. This error message usually indicates the link from an item in Media Library to its associated digital media file is broken. Items in Media Library are links to digital media files that are stored on your computer, a network drive, a removable storage card, an Internet server, or another location. Links can be broken for one of the following reasons: * A link to a temporary file from the Internet cache (for example, a file from the Temporary Internet Files folder) was added to Media Library and that file was later deleted. * A link to a digital media file was added to Media Library and the file was later deleted. To repair a link Do one of the following: * If you deleted or moved the file, replace it to its original location. * If you moved the file, right-click the item in Media Library, click Error Details, and then enter the new location of the file. To delete a link Do one of the following: * Right-click the item in Media Library, click Error Details, and then select the Remove file from Media Library check box. * Right-click the item in Media Library, and then click Delete from Library. Good Luck, Tim
Feb 04, 2007 | HP Pavilion zv5034US Notebook
SanDisk Sansa e250 MP3 Player Logo
511 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
