Question about Watches
Removing watch links
How do you get the little pin out between links. Does it unscrew or just pust out. This is a Seiko casual watch.
Thanks!
    Scholar:
  • 67 Answers
Look at both ends of the pin. One will look smooth, the other appears split.
You will need a suitable soft (wooden) support, and a very small dia. punch and a light hammer. The rest of the watch can be protected with a soft cloth.
You place the punch on the end of the pin which looks split, after arranging the watch so the link you are driving the pin from is supported on the edge of the timber. I drill a hole close to the edge of the timber over which I place the pin to be removed. Then by gently tapping the punch with the hammer, the pin should slide down into the hole.
One pin needs to be removed completely, the other can be left in the next link ready to tap back in after the link you wish out is removed.
The important thing is to have a decent punch! The diameter must be such as to fit easily through the pin holes, and the end should be flat. If you cannot make or find a suitable punch, one could be made from something like a darning needle.
Posted on Feb 22, 2008
How do I take out links in a seiko SUR072 watch band.
Without seeing the band design, Seiko has a couple of executions that they use. One is a pin which is flared on one end. There is usually a directional arrow showing you which way the pin gets driven out. You will need a small hard pin. It should tap out, after the flared end is exposed you can pull it out with a small pair of plyers or side-cuts. Push out the next pin in the next link then put the pin back in the way it came out. The flared end is the last piece that goes into the band. If this doesn't work try a store where they at least install batteries. Good Luck hope this helps. Gabe
Dec 30, 2014 | Seiko Watches
How do I remove links from a Seiko watch band?
Follow these steps and it will help u resize your watch.
1-Take a good look at the watch bracelet. Seiko watch bands are equipped with one of two different types of pins holding the links in place. One type is a simple, nail-shaped pushpin that's inserted into the joint between two links. The second is a flat, L-shaped piece of metal that slides into the center of a link and locks it into place. Both pins are removed using the same process. If the nail-shaped pushpin is present, you'll see the tiny screw heads in the joints. If the L-shaped pin is present, the links will be open-sided and you'll be able to see a strip of metal inserted in each links.
2-
Look for the arrows on the inside of the watch bracelet links. The arrows indicate the direction the pins and links need to be slid off of the band. Any attempt to go against the arrows could break or warp the links.
3-Remove the spring bar from the clasp with the small pin-removal tool. Set the watch up on it's side so that the top of the spring bar is facing up and the bottom is flush against the table. Put moderate pressure on the top of the spring bar and tilt the watch just a bit sideways so that the spring bar can slide out. Ease out the bar slowly and carefully; the spring bar is spring-loaded and will shoot away from the watch if you're not careful (make sure that the bottom of the watch is pointed away from you at all times). Put the spring bar in a small dish so it doesn't get lost.
4-Line up a small pin-removal tool with the top of the pin and push in the direction of the arrow until it slides out completely. Slide off the link. Place the pin and the link in the small dish. You'll want to save them in case the watch needs to be re-sized again at a later date. Continue removing links, alternating sides of the band to keep it even, until the watch reaches the desired size.
5-Reconnect the watch. On the side opposite where the spring bar was removed, line up the link connected to the clasp and the second link on the band. Slide the pin in the opposite direction of the arrow, using a flat-headed pin inserter to push it into the joint. Use the pin-removal tool to give it a final push, listening for the click.
6-
Reinsert the spring bar slowly, using the pin inserter. Make sure the spring bar is lined up and tightly in place to avoid injury.
Try this and it you cant manage it then you need to get it to a watch repair shop specializing in that brand.
Jan 09, 2011 | Watches
Ive had my Seiko automatic titanium scuba 200m about 3 years when i got it, i had it sized down by taking out 3 links which the store gave me back and 3 pins that go with , ive put on a few pounds maxed...
Thanks for contacting FixYa.
Seiko normally will send out up to 5 extra links on new watches. I am not sure on watches that are 3 years old but you will need to contact Seiko on this one. MAYBE a watchmaker locally will have some extra peices that will work too.
You can contact Seiko here:
http://www.seikousa.com/support/customer/northamerica.html
Best regards.
Jewel
Aug 30, 2010 | Seiko Diver's Watch
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
How to remove back cover and change batery. This is a Seiko watch, Stan Bixler sbixler@socal.rr.com
Not sure which Seiko this is. If it does not have a snap back case the it is a screw on case back. A special wrench is needed to unscrew it. If you don't have a case back wrench you will either need to buy one (the good ones that won't damage your watch are about $50 US) or take your watch in and have the battery changed.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Seiko 0512037FA Wrist Watch
Seiko Watch band Adjustment
hi. you have to push or hammer the pin out in the direction showen by the arrow, so the arrow is dis-assembly direction.
May 21, 2008 | Seiko Diver's Watch
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Watches Logo
2,032 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
