Question about Moyer Diebel 48 in. SW400 Dishwasher
Moyer Diebel Model 201LT heating element failures
I've replaced 3 tank heating elements in my machine in 10 months. The elements have a number of tiny pits and then one breaks thru to the interior
and produces an inch long crack when it shorts out. I'm using Eco Lab products. Eco clean Elite Low temp for cleaning agent and Ultra San, Low Temp Sanitizer. The last Tech measured the chemicals and said the proportion was in the low range for soap & sanitizer use.
    Scholar:
  • 86 Answers
Without looking at your defective elements it sound like the chemical eat through the element and produce tiny pits tell your Eco Lab Tech to change to another type of chemical they have many kinds to suit your need. Try that . God Bless.
Posted on Jul 04, 2009
No heat in 501 LT
There's only 2 wires doesn't matter which goes where. Check the hi-limit (small round disk) push the button with power off. You'll feel Click if it needed resetting
Aug 22, 2012 | Moyer Diebel 24 in. 501HT Built-in...
J have a moyer diebel 500 HT i need a picture of the tank were the heater elements go ..i had a repair guy com in to wire the heaters up because they shorted out and he wired them wrong if you can help me...
Hello there
The 500HT machine is very old one. Turn off the power first. To get to the elements you have to get the control box off first so you can get to take off the elements cover , now you can see the elements.
If the system have been wired wrong and short circuit it. the temperature control may have to be change too. I would change the two elements and the temperature control and the hi ltd control all together at the same time so you know that system have no problem anymore. All the best Dickson
May 02, 2011 | Moyer Diebel 24 in. 501HT Built-in...
I can not get the water temp to above 180F and the local health inspector realy want it to have the minimum of 71 degree celcius or 180F.If I leave the machine idle the temperature gauge show 72C but as...
Hello Huekycanada
You have to check the booster element what amp they are drawing there are three elements if only two are working it will still goes up to 72C may be it need longer time to get there. Secondly I would check the in coming water from your hot water tank it should be 60C at the machine , To check this incoming water temperature the best way is checking the temp. at the sink nearest to the dishwasher. 9 out of 10 I do find this is the main cause of the problem ( the in coming water temp is too low)
All the best, Dickson
Apr 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Our dishwasher isn't cleaning very well, and I noticed that there looks like a scaley build-up on the heat element and looks like the holes are plugged on the washing arm. Is there anything that we can...
you can use any kind of calicium lime and scale remover to help clean the dishwasher,there are also several kinds of dishwasher cleaner that can be bought from most any store around. it may take a couple of times for this to work and clean the dishwasher.
Make sure to run it on a empty cycle it run for a few minutes the stop the machine and let it sit and then restart the machine.
Dec 22, 2010 | Moyer Diebel 201LT Dishwasher
Heating Element not coming on
Check the heater wiring with a voltmeter. Should be around 208v to 240v. If ok then turn off power and remove one heater wire and check heater with ohmeter for continuity. Replace if no continuity.
Nov 08, 2010 | Moyer Diebel 48 in. SW400 Dishwasher
I would like to purchase a Moyer Diebel U/C dishwasher for residential use. I have the option of purchasing a used dishwasher - it could be one of three models. Which one is the model he is trying to sell...
The way you mentioned the unit have a 4 ft. cord at the back seem like a 50l LT the best way to determent is open up the bottom plate and see whether there is a booster tank in the right hand side.
Hope this can help you.
Mar 12, 2010 | Moyer Diebel 24 in. 501HT Built-in...
Moyer diebel 401 ht not reaching temperature ????
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Oct 11, 2009 | Moyer Diebel 401HT Dishwasher
Moyer Diebel 48 in. SW400 Dishwasher Logo
140 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
