Question about Lexmark Wheelwriter 5 Series II Typewriter
LED 1, 2, 3 blink machine doesn't work
Any ideas?
  • 478 Answers
If it beeps three times then the line space lights blink
1 the batterys are installed incorectly
2 no batterys are installed
3 the batterys are weak or dead
Posted on Feb 23, 2008
My hitachi ac disply led 7 times blinking red light machine not working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand.
http://electro-medical.blogspot.com/
Jul 10, 2016 | Hitachi Televison & Video
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Safesense led continues to blink when power on
Below is the manual for your shredder. Does the shredder still work even though the LED blinks?
Fellowes Shredder Manuals
Sep 19, 2014 | Fellowes Products - Powershred P-58CS...
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Router doesn t work
1- check the wireless led if blinking .
2- if not , push the wireless button .
3- check the led blinking again .
4- if not , the problem will be with your router electricity , you might change it .
Aug 10, 2013 | TP-LINK Computers & Internet
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
My tv rca tr29e26 it have the front panel LED constantly flashing and it doesn`t turns on while is connected !!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 09, 2011 | RCA TruFlat 27F520T 27" TV
Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
May 12, 2011 | liftmaster Chamberlain Garage Door Opener...
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
End led blinks 3 times
Had this exact problem (fills, empties and then light blinks three times) and found that the heating element was burnt out. Very easy to replace.
Nov 06, 2008 | AEG Lavamat W1050 Front Load Washer
Lexmark Wheelwriter 5 Series II Typewriter Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
