Question about Acer AL2671W 26 in. LCD Television
Power on and off
My tv works fine, but some time it truns off and goes dead, then i have to turn it of and on again. all else is fine.
  • Anonymous Apr 15, 2008
    I must turn tv on and off in order to correct closed loop, sometimes for several minutes.
    Problem Solver:
  • 7 Answers
Switch on/off may work for a while - the problem is the power board: costs aprox. 150,-$...can be changed easily (if you have some expirience).
MfG
Posted on Feb 27, 2008
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Jun 12, 2011 | Toymax Magnavox 47MF437B 47 in. LCD TV
My LG LCD TV will turn off by itself. I will unplug it and leave it for about 1o Min, plug it back in and it will work fine.The TV will sometimes work for days before this proble reoccur
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care......
May 06, 2011 | Sanyo Televison & Video
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Sony Bravia KDL-46Z4100 - tv turns off after being on for several minutes. turn off, back on and it continues to run for several minutes then goes blank again. Standby light flashes 12 times
Ur tv power supply board have dead parts call capacitors.U know basic electronic's and soldering?Take ur tv aparts,check the power supply board,that the board the power cord plug into it.Searches all around for these dead gas leakage capacitors,they all way bulges up on it top,or puff up on it top.Replaced these dead gas leakage capacitors,ur tv will have stable LED light and the power will work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 24, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Tv shuts off automationcally while watching
Take ur tv aparts,where the A/C power cord goes that ur power supply board,check it all around the power supply board for those dead capacitors,they alway puff ups or bulges up on it top.U know basic electronic's and soldering?These capacitors have leakage gases it dead.Replaced those dead capacitors ur tv power will stable again and work.Or tires websites like Shopjimmy.com,Ebay.com to buy a whloe refurbish power supply board for the replacement.
May 11, 2010 | LG 32LC7D Television
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My sd-582hd5 picture goes black
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Power on and off
Do you know the board number needed to fix the TV?
Mar 31, 2008 | Acer AL2671W 26 in. LCD Television
Acer AL2671W 26 in. LCD Television Logo
190 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Jaime Hernandez
Marvin
Marvin
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
