Question about Mitsubishi WS-55807 TV
WS-55807 Has developed a very noticeable screen discoloration within the portion of the screen where a 4:3 picture would be. The sides or pillar bars that are used only for 16:9 have good, like-new color. It looks as though the 4:3 portion of the screen has worn out because it has been used far more. Could this be fixed by replacing some component of the screen? Thank you, Dave
  • Anonymous Mar 01, 2008
    shadows on screen .. never go away
    tried all ajustments no improvement
    Scholar:
  • 52 Answers
Get your remote and go into the menu and see if you can find the "horizontal static convergence" adjustment, or it might just say "convergence". You have a small chance that this will solve your problem. Also make sure that nothing with magnets is located near your set. They will distort the color if too close to the set. Also, if you have a friend who is in electronice, see if he/she will loan you a degaussing coil and show you how to use it. You do not have to take the tv apart to use the degaussing coil and it takes only a few seconds to degaus. Go to http://www.twobits.com/degauss.html and learn in laymens terms about this tool.
Thanks.
Keever
Posted on Mar 04, 2008
Black vertical bar on right side of screen
ws-55511 Model?
If so, look with set on a not used video input to see if can see discoloration there also---also look other side for it.
Let me know what you find. Answer is based on model number given.
Apr 30, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Mitsubishi big screen blury
In all probability the picture is fuzzy too, its just harder to notice. This can be as simple as an adjustment in the back of the set. Carefully remove the back and look for the flyback transformer (part with large red wire coming out of the top). The should be 1 or 2 controls on it. One should be marked focus. Adjust that to get sharper focus.
Let me kow if that fails to resolve the problem.
Thanks,
Dan
Sep 30, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
White permanent lines on Mits 55
if you have had the pillar box on for a long time and now you are viewing wide screen format the crt's have had more or the phosphorus worn on the 4x3 portion of the crt's witch will give you a different shade where the pillars were the only cure is to replace the crt's
Oct 14, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsu 55'' screen
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs (STK392-570), have a basic knowledge of electronics and be able to use a soldering iron.
Feb 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
