Question about Samsung CLX 3160fn All-In-One Printer
Imaging unit Is there any way to reset the imaging unit back to zero
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
No, the imaging unit will only reset back to zero if you replaced it.
Posted on Mar 14, 2008
  • richard ellis
    richard ellis Feb 26, 2014
    i have repalced the imaging unit but error still there
How to reset the printer drum
no risks no reset change chip on drum unit
Jul 31, 2014 | HP Laserjet Pro CP1025nw Color Printer...
How do i reset the trouble code c 2259
Black image unit motor failure. First open the front door remove the black image unit not the black toner!!!. Take the image unit and shake it so as to spread out all of the developer & toner inside the image unit along the whole length of the unit. The reason for this is as not have all of the developer/toner all at one end and the motor trying to turn with all that at one end or the other. Never store image units or toner vertically!!!!!
Now reinstall the image unit. and close the door. Opening and closing the front door will reset the machine . If it comes back good chance bad image unit.
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C451...
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Electricity went out and my sub zero will not stop beeping
I would turn off unit by the control, then turn back on to reset computer, if this does not work or reset get back to me and we can do a force start.
Thanks
Nov 21, 2011 | Sub-Zero Platinum Stainless Steel 632/P...
Thermafax wont transfer image
try reseting your machine , turn the unit off at the power source for 3o seconds and then switch it back on this may reset the unit
Apr 09, 2010 | Panasonic KX-FP121 Plain Paper Thermal Fax
Showing h4
If your machine is AR-5316,
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
How to reset the unit...
Reset what? The imaging unit or the toner cartridge? Replace with a new one or get a recharged one.
Feb 07, 2008 | Kyocera KM-1505 Copier
Resetting the imaging unit
How do you reset the imaging unit?
Dec 19, 2007 | Samsung CLP-510 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
355 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
