Question about Philips Audio Players & Recorders
PHILIPS 22DC278/62 car cd player. Any cd put in just gets cd err response. Have disconnected and re-powered with same problem. This seems like a common fault? Any help would be appreciated. Scotty2175
robotek
  • 1512 Answers
SOURCE: cd player fault quick fix any one?
You can do a few things to see what may happen.
  1. Check the spindle height. The platters sometimes slip down the shaft, or the spindle motor bearing drops and the platter gets closer to the lens.
  2. check that the spindle motor has not become lazy and "poling". give it a few spins. then try to read a disc again.
  3. Clean the laser lens with a cotton wool bud moist with windex glass cleaner. Then "polish the lens with a dry one.
  4. the spindle motor top bearing is worn and the payer mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. More likely to happen at the start of a disc, because the disc is spinning fastest whilst reading the TOC.
A drop of light machine oil from a syringe oiler can help the bearing to spin an not produce the knock. Only a short term fix to give the motor a "lube". Once the oil leaches out of the worn bearing the problem will return. I have run motors immersed in an oil bath to rejuvenate them before... but better to replace it anyway if its suss at all. Good luck, You could bump my profile by giving me a "FixYa" rating for my sharing my "knowhow". Any problems check back with me here.
regards
Graeme.
Posted on Feb 10, 2008
  • 71 Answers
SOURCE: code for car radio philips car2004
All car radio codes are kept by the car manufacturer and you need the dealer to contact them for you using the radio's serial number.
Posted on Mar 10, 2008
  • 351 Answers
SOURCE: Hi, I took off my car
Dear Memo,
you can download the manual for this ,player, from this site:
http://www.devicemanuals.com/guide/Car%20CD%20Changer/Kenwood%20French/Kenwood-French-KDC-MP625-CD-DVD-Changer-Owner's-==TVRFd05qVXk=.html
in this manual you can get the security code for this Player also.
Cheerup and be happy always
Posted on Mar 27, 2008
shaggyrat
  • 1224 Answers
SOURCE: i have a philips cd
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
Posted on May 07, 2008
shanat
  • 359 Answers
SOURCE: Err on CD player....2005 Honda CRV
it sounds like it may have a bad laser or even dirty try removing the cover and gently cleaning the lens if you dont feel confident i would suggest you put it in for a repair usually removing the battery lead for up to half an hour will reset the system and put it back to its original state but its suggested if it doesnt then its internal usually the laser.
Posted on Jun 04, 2008
Messed up screen horizontal lines
Keep in mind that active mobile phones can interfere with the Philips CD/MP3 players function.
Try to reset your player by ridding it of electrostatic discharge: Disconnect power or remove batteries for a few seconds
I don't know your model number so I could not research it further. Go to the Philips support site and put your model number in, from there you can look up downloads of firmware if available and also downloading the manual to troubleshoot. Here is the support site:
http://www.support.philips.com/support/find_product.jsp?userLanguage=en&userCountry=be
Jul 30, 2014 | Philips Sport Personal CD/MP3 Player
I have a Philips Micro System DCM 292/05 Serial no AQ1F1049017669 purchased 28.3.11. The CD will not play displays Reading then displays Err Disc top left displays a pic of a disc &DBB I have...
The laser's reflected signal is no longer detected. All you can do is to clean the unit with a lens disk like
http://www.amazon.co.uk/Hama-DVD-Laser-Cleaning-Disc/dp/B00005UPDF
If this fails then the laser diode has failed and the optical unit is dead - it will have to be replaced.
Jun 13, 2011 | Philips Audio Players & Recorders
Philips CDC3 Disc changer keep getting error check CD
Sorry, not a solution but I have exactly the same error.
Hope someone can give us a fix - I'm on my third CDC3 changer already..... Not very reliable are they?!
Jan 06, 2010 | Philips Audio Players & Recorders
I put my CD into my CD player and it says ERR but
Bang on the fascia as close as possible to the cd player a few times it will eject.
Regards
Phillip
Sep 12, 2009 | Car Audio & Video
CD problem
the lens is not good that why it can't read the cd,the lens must be replaced,but it is better to buy a new car cd player,as if u change the lens ,it does not last for long
Aug 17, 2009 | 2000 Nissan Sentra
Bouht Philips car radio CD player at car boot,I've
In most cases the "pink" could either be for an automatic antenna OR remote control unit / The red wire in most cases is to keep the "memory" active on the unit (preset radio stations/clock)....
Jul 28, 2009 | Philips Car Audio & Video
HELLO MY I AMHAVING A PROBLEM PUTTING PICTURES ON MY PHILIPS MP3 PLAYER. WHAT SHOULD I DO?????
There is a key plug-in (Philips Device Plug-In) that came with the installation CD for this model that is critical for getting pictures to work properly. If Philips no longer has the install CD, try ordering it from anywhere.
Dec 30, 2008 | Philips GoGear HDD6330 MP3 Player
PHILIPS CDR778
My CDR778 display reads OPC ERROR .How do I reset it ?
Mar 06, 2008 | Philips CDR778 2-Disc CD Recorder
205 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
