Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker hole in microwave door
I just have the hole in the film($12) and a small burn mark on door main($50). It looks like I can remove the interior film and wipe off the metal grid. I'd like to clean it off and replace the film.
1. My main concern is if the metal (door main ASM, $50) needs to be painted or can it be left bare?
2. Do I need to unplug and discharge the "stored energy" just to clean and replace the film?
I would prefer not to replace the anything that needs to be unscrewed or
take the door completely off.
http://www.pcappliancerepair.com/model-display.php
  • 1 more comment
  • Anonymous Mar 06, 2008
    Same problem, bought the film from GE Appliances, but don't know how to install it.
  • Heidia64 Apr 15, 2008
    I have burn marks on my microwave door.  Can these be removed and if so how?  I have tried to wash it off but have had no luck.
  • rosiecheeks Jun 11, 2008
    Same problem here. There seams to be grease trapped between the door and the film on the door. Tried bowl of water in the unit.....but that didn't work. Please help...it looks aweful!!!
5 Suggested Answers
renosean
  • 492 Answers
SOURCE: hole in film on interior door
I would consider buying a microwave in the near future, or at least not standing there watching your food cook the whole time. The film works with the grid with the small holes in it to eliminate the microwave radiation that the unit produces. A hole in this film compromises the intergrity of the unit. Essentially it would be like tryring to create a dark room with no light and having a hole in your covering, creating an escape for the light to get through.
Posted on Mar 11, 2008
  • 579 Answers
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Posted on Jan 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Metal singed on microwave door: your response
Sorry I don't have the paint or parts. I mostly do repairs.
The paint should be available at big box stores like Wal-Mart, home improvement centers like Builder's Square, Lowe's, or Home Depot, or hardware stores or local appliance parts stores.
You can order the plastic sheet (called the "door film") here. It is part # WB06X10490.
Be sure the mesh is clean and dry before installing the new film.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
breddi2
  • 126 Answers
SOURCE: Damaged door on microwave
The glass if you look at it has a screen sandwiched inbetween glass that dicapates the energy from exiting through glass. If it is burned to that depth then concern would be a priority. The screen should still work as normaly would,but if it is bare to the interior then it might get heated when unit is operating.Replacing glass is not to bad to do,the inner side has plastic insert that snaps in and can be removed by prying it out < using small flat tool such as slim puddy knife and then ther may be a few retainers for glass> it snaps in from outer edge.
Posted on Apr 22, 2009
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Feb 09, 2015 | GE JVM3670SK Profile Spacemaker XL1800...
Why does ge microwave blows fuse when door is opened?
Inspect the door switches and the wiring in the light bulb circuit. If the problem is a door switch, it will probably be visibly broken, or there will be burn marks on it. It's also possible that the door switch bracket is bent or broken and allows the terminals to short to the oven frame. Check the lamp socket - if it is cracked or burned, it should be replaced.
Also look for signs of arcing or burn marks on the controller board, especially near the relays (usually black plastic boxes about 1" x 1' x 3/4' mounted near the wire terminals or wire harness connector).
As a general note, it is rare for a fuse to fail by itself. If you find a blown fuse, look for a cause before replacing it. This may prevent wasting another fuse.
Jul 01, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
DEBBILS@COMCAST.NETwhere is my light bulb it burned out. I have a ge compact microwave oven. Model number is JES 1139WLO3
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave xl1400 works but does not heat
Pledase check the operation of the door safety interlock system. If you routinely open the door while the oven is operating, these small switches will eventually burn out and not work.
Oct 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The mesh screen on the inside door has a hole in it..
would suggest replacing door for safety purposes only," it could be fine as far as resisting waves",but never sure for how long or if it realy is. An old saying makes sense," Better safe than sorry".
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile
Some burns are not cleanable. Use of soap and water is the safest way to attempt cleaning it. If it burned the paint, then it will need to be touched up with G.E. oven cavity paint ONLY, which your local dealer or servicer should be able to get for you.
Do not attempt to clean it with any flammable or toxic solvents.
May 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hole in film on interior door
wouldnt be concerned about hole in the film strictly cosmetic!film wouldnt be available youd need t repalce door and thats just not feasable
Mar 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
545 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
