Question about Royal VF1000MX Shredder
Shredder won't accept paper on left side
When I try to insert paper to shred, there seems to be something obstructing the left side, but if I angle it in to the right side, I can then slide it over so the left accepts it. I've lost my manual.
I think I could clear it if I could get the top off and apart, to expose sensors and grinders, but can't figure out how to get it apart.
Will welcome help!
  • Arlingtonian Mar 01, 2008
    fellowesrep was right. After I removed the screws holding the top unit (with the shredders) from the base, I could see deep-set screws. Took them out, and got the unit apart. Found that we had shredded some sticky labels and/or tape that were gumming up the works. Pulled it all out, using needle-nose pliers. Put it back together, and now it works like new. Total time, about 30 minutes. Next time, I could do it in about 10 minutes. Thanks to fellowesrep!!
    Scholar:
  • 102 Answers
If you think you have taken all the screws you may not know that most often there will be a hidden screw ot two under a sticker or a plug.It may be that your unit has tabs that simply need to be pulled apart. Unfortunately I only know Fellowes products but maybe this will help. Good Luck.
Posted on Feb 25, 2008
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
I have an Ativa 1850. When putting papers in to shred the papers move to the right side and bunches up the paper. The shredder now doesn't want to work properly. No papers will go through to be...
You probably need to get some shredder oil and lubricate the cutter heads. see: http://www.walmart.com/ip/Fellowes-Powershred-Shredder-Lubricant-Oil/8207323
Apr 19, 2011 | Office Depot Ativa 1850 (MicroCut)...
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
If I put the document in straight it won't shred. I can get it to shred if I insert it on the left hand side - there seems to be some kind of jam on the right hand side.
Unplug it first. If you are certain that there is a jam, take the top off and flip it upside down. Use a pencil or other object that is NOT YOUR HAND and try to remove some of the paper jammed up. It is also possible that there is only a sensor on the left hand side. If this is the case there isn't much that you can do. Hope this helps and tell me how it works out!
Oct 07, 2010 | Aurora Electronics AS890C Shredder
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Royal VF1000MX Shredder Logo
231 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
