Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 42" flat screen LCD T.V.
We recently purchased a Sharp 42" LCD TV. A month after purchasing the set, the screen developed a thin, but noticeable, blue line running from the top to the bottom of the screen. It is there anytime we turn on the TV.
  • 5 more comments
  • Anonymous Aug 28, 2008
    same problem in 37 inch
  • Anonymous Sep 16, 2008
    same blue line on 19 inch
  • Anonymous Mar 15, 2014
    Sharp Aquos LCD TV - When turned on the screen is simply bright colourful vertical lines with circles formed on top of the lines. What is this??
  • Anonymous Mar 17, 2014
    I purchased a 60" a year ago. I have 2 straight black lines running across the screen,
  • Anonymous Mar 25, 2014
    It's a 42" Flat screen TV all it has on it is TCL.
  • Anonymous Mar 29, 2014
    DOES NOT SEE USB
  • Anonymous Apr 01, 2014
    Exactly down the middle of the screen the left side is a subtle lighter gray than the right side which appears normal. Is the tv going out or does it need reconfiguring? If so what needs to be done to correct it?
  • 103 Answers
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
I have a Sharp Aquos 42" wll mount TV. It has worked wonderfully until yesterday PM. I turned it on (with the remote and with the units manual on switch), the green on-light illuminates, the screen goes dark blue, but no image or sound. The TV is on cable, and I have reception in other parts of the house from the same cable system. The unit has not been moved nor have the cables been touched. What might be the problem?
Posted on Mar 05, 2008
    President:
  • Sharp Master
  • 1,779 Answers
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Posted on Feb 22, 2008
I have a Sharp Aquos LC-70SQ15U that is about 3 years out of purchase.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 28, 2017 | Sharp Televison & Video
How to troubleshoot b159-001 power board
https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Aug 13, 2013 | Sanyo DP42746 42 in. Plasma Television
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
Hi, I've purchased a 2nd hand LG 42" Plasma TV set
Usually black lines in a flat panel indicate an error or problem in the video board. A service professional can hook up to the tv and better diagnose the issue.
Mar 23, 2011 | LG Televison & Video
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have the same problem. I recently purchased a Sharp LC-52D78UN TV and I am receiving nothing but Black & White pictures when connected to Direct TV cable receiver. Why and how can it be fixed. I...
I suggest you check the cable input system. It is possible that the cable unit produces S Video or B-G and the TV is set up to receive standard quality RGB.
Hope this helps
Nov 21, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
Sharp LCD 42" picture to dark
No, just go into your setup, and adjust the darkness. Should work for you.
Feb 21, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,052 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
