Miele Front loader washing machine w 980 wps
The machine stops completely, no lights as if it had been switched off at the socket. Sometimes it restarts after a while and completes the cycle, sometimes it alarms and the timer shows a series of three dashes and the red "check inlet" light comes on. We cannot find the instruction booklet. The machine was bought in 2000.
    President:
  • 1,294 Answers
Click on washing machines (below FIXYA )on this website, type in your brand,model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 23, 2008
Miele front loader. Approx 20 years old. Rinse light is flashing & it won’t spin. What could be wrong with it? Thank you
The usual clean filter leading to pump anything stuck there will cause the machine to stop is the machine a dial type or elettronic processed if is manual and pump is clean it could be the dialler in wich case not an economical repair also check belt to the motor.hope this helps
Feb 02, 2018 | Miele Washing Machines
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Hi I have a miele W460 WPS Washing machine which has today stopped working it has 2 flashing red lights next to check inlet outlet warning. I have done this and both are fine. How do I get it to start...
my advice open the pump filter at the bottom of the machine (on left side) ensure all is empy.
the other option is turn off the machine at the maions using a vax water hoover (or any wet and dry vacume cleaner) remove the wast pipe from sink put the hover pipe to the washing machine and **** out all the water.
sould this also fail you would need to open the machine and check the bottom on the floor (inside the machine where all the workings are) there is a cut off trigger make sure this is completely clear of any thing there would be a polystireene base with a button trigger if this is activeted it will stop the machine and cause it to continuesly run the pump this should resolve the issue please let me know how you get on i can come out into certain areas to see to this machine but i charge £50 labour charge 9 out of every 10 of theese i manage to get going again let me know my email is carlwallis20@hotmail.com
Dec 23, 2009 | Miele W460WPS Front Load Washer
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
