Question about Galaxy Radios DX-33HML 40-Channels Base CB Radio
North Star DX 330 HML has no receive
North Star DX 330 HML has absolutely no receive. TX and modulation work fine. The external speaker doesn't put out any sound as well as the internal speaker. The meter indicates no receiver either.
  • Anonymous Mar 26, 2014
    no am mod ,meter goes up showing power but no audio heard on other radio, works fine on FM & PA speaker.
    Meter moves up but no audio, no mod on AM ( only dead key ), FM & PA speaker works fine.
  • 204 Answers
Radio dude, we'll try to help with the problem your having with your Northstar base. I assume you have checked all the controls to make sure they are functioning correctly? ok, based on what I'm reading for the problem, I'd say your looking at a bad solder joint on the main circuit board, or a close powerful station might have keyed up and blowed the front end out of your receive. There are 1 or 2 fet transistors in the RX chain and with the age of the radio, one of those going bad on it's own is a possibility. Sounds like it needs some hands on troubleshooting, are you electronically able to work on it?? Hope this helps in your search and let us know,, Mechanic
Posted on Feb 23, 2008
Onkyo tx-nr509 no sound
check to make sure the speaker wire is not touching on the back of sterio or speakers. then shut off and turn back on. check the menu for speaker a and b and make sure it is turned on
Mar 13, 2013 | Onkyo TX-NR509
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy 33 hml
This is not a simple answer not knowing if it ever worked or not. I have a rfx75 installed on a DX 88 and it preforms flawlessly. If I were you I would find a reputable CB Shop and ask for their help.
Jul 03, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Onkyo TX-SV525 Receiver - remote channel not working
Could be failure of one or more of the controls you mention.
Dec 27, 2017 | Onkyo TX-SV525 Receiver
G959 mod meter will not work but modulation is 100% others rfine?
If its the meter on the radio don't worry about it they do go bad but it won't effect the radio. My shops in North Florida. And no I have no web site at this time.
Apr 27, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
External jack
sounds like you got a good radio to practice on . If it was given to you then you have nothing to loose except what ever you put into it. try hooking the speaker jack back up, see what it does??
Apr 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Mar 02, 2008 | Onkyo TX-SR800 Receiver
Bose Acoustimass power
the amp is overheating. Disconnect one speaker at a time to see if problem persists. If so, the amp needs serviced.
Nov 08, 2007 | Onkyo TX-DS575 Receiver
Galaxy Radios DX-33HML 40-Channels Base CB Radio Logo
371 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
