Question about Nintendo Game Boy Advance Console
How to fix a 1988 kawasaki bayou 185
My 4weeler wont start, the air going into the carbouretor is not taking air in, its just blowing it back out. if u can please help me as soon as u can
    Genius:
  • 1,019 Answers
Hi Buddy,
Wrong category, this is for Video Game Consoles.
If it,s any consolation, i,d suggest that your timings out on the casing, if your getting a missfire.
Try push starting it or towing it, and banging it into second gear with the ignition on. Check that your ignition timing belt or chain has,nt slipped or Broken.
Clean And re-gap the spark plugs.
This should solve your problems. up n Runnin.
Mike @ Compurepair.
Posted on Feb 22, 2008
Kawasaki bayou 300 starter spins but wont engage all the time
The larger idler gear ring was spinning but not spinning the entire gear. I couldn't figure ... Starter Idle Gear Limiter Kawasaki Bayou 220 250 39076 1060 ' eBay ... kawasaki bayou 300 starter will not engage.
Mar 21, 2017 | kawasaki Motorcycles
Carb sprays gas toward the air filter on a 2006 kawasaki bayou 250 what would cause this?
timing may have jumped and bent the intake valve causing it to blow back into the carb on the compression stroke.
Mar 09, 2017 | kawasaki 2006 Bayou 250
86 kawasaki 300 bayou, turn the key on, hit start button and there is nothing. i did find a wire terminal on the regulator / rectifier Fixed it and still nothing. what component should i look at..?
Hi, Lee and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
kawasaki bayou wont start
ATV Connection
DOWNLOAD 1986 Kawasaki 300 Bayou
http://www.bikebandit.com/aftermarket-parts
Owner Center
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 27, 2016 | kawasaki Motorcycles
Kawaski bayou 300 stater wont engage engine all the time why
Hi, Gary you may have a starter solenoid or starter drive going south for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
bayou 300 starting problem Kawasaki ATV Forum
1986 Kawasaki Bayou 300 Starting Issues
Kawasaki Bayou not starting
Owner Manuals Service Manuals Kawasaki Vehicles
Jan 25, 2016 | Motorcycles
My 1995 Kawasaki bayou 300 will not start it has a spark gas to the Carb and a new battery it cranks and cranks but will not start. How do I get it to start someone please help I wanna go riding..
Hi Abbott:
You've gotta be close. Let's double check.
- Pull the plug(s) and make sure they're not fouled and that there is a nice hor blue spark across the electrode.
- Fresh gas in the tank
- flush the carb (drain plug)
- Fuel filter if there is one.
- Clean the air filter.
Put it back together and give it a try. If it runs, great, if not, pull a spark plug and see if it is "wet" with gas. If not, the problem will probably be with gummy bad stuff in the carb. Take it off, and an air hose to try to blow out all the little passages.
Keep smiling, you'll be killing bugs in no time!
Apr 22, 2015 | kawasaki Motorcycles
How do you line up the timing marks on a 1988 Kawasaki Bayou 220 ??
http://www.mediafire.com/download/j8p6ew6gty8cd44/2003-05+Bayou+250+Service+Manual.pdf#2 for a newer 250 but I think they're all the same
Feb 02, 2014 | kawasaki ATVs
Where can i find wiring schematics for a 1988 kawasaki 220 bayou atv
Hello Cgranny39 you find the wiring schematics for a 1988 Kawasaki 220 bayou atv here at this link. You can buy it at amazon.com. Here is the direct link http://www.amazon.com/dp/1563925222/ref%3Dasc_df_15639252221084244/%3Ftag%3Daskcomel-20%26creative%3D380333%26creativeASIN%3D1563925222%26linkCode%3Dasn
I hope this helps!!!
Apr 27, 2010 | Electric Eyeware Atv Mojave Kawasaki...
I have a 2006 Kawasaki Bayou 250 it is always fowling spark
Take the carb back off and adjust the float in bowl to spec.If you don't have spec just adjust till fuel stops overfowing an go with that.Yeah, it might take a few times.
Mar 21, 2010 | 2006 kawasaki KLX 250
Nintendo Game Boy Advance Console Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
