Question about Ricoh Aficio CL7100 Printer
Ricoh CL7100 Error code SC391-4
We have a Ricoh Model number CL7100 Color Laser printer. It has worked fine and only has 2,000 prints on it. When we moveed it to a new location and turned it on it is now coming up with an error SC391-4 code right after it attempts to cyle through the start up processes. Can anyone help?
  • Joe Sarpino Feb 25, 2008
    I think you may be on track, here is what I have found. I first "swapped" the Cyan and MagentaPhoto Conductors made no difference in error code, so I then removed the color keys for the magenta and cyan toners, then reversed the toner and the drums as a matchig set, still came up with the same error code of SC391-4. I did notice something interesting though, whichever drum and toner set was put in the cyan position when it errored was the only drum to have a coating of toner on it after cylcing through the start up procedures. It appears as if maybe there is a problem with the transfer roller charge or the drum charge but am not sure where that is applied. I did clean the contacts on the front side of the machine that contact the drums. But did not disassemble the rear area to check that. I did look into the contact area after removing the transfer belt and drums and toners but could not see anything that looked like a bad connection, and I cleaned all the metal contacts on the actual drum and toner cartridges. I think that the photo conductor that sits in the cyan posistion is always the one that has a coating of residue would seem to support your view that is has something to do with the Cyan PCU. Appearantly I am not correcting the right connection. So do you have any additional places I should be looking, or suggestions?
  • 87 Answers
Reseat the cyan PCU .
Posted on Feb 23, 2008
  • Dale Richards
    Dale Richards Feb 26, 2008
    There should be spring on the end of the PCU. That is the charge connection. With the excess toner, you have no charge, ie solid copies. It is just depleting the cyan developer. It is obviously not the PCU itself, if you swapped them out. It could be the connection on the rear side of the machine.(either side of the terminal) The back of that machine of a pain to take apart, so if you do, pay close attention.
  • Dale Richards
    Also, reseat the cyan developer unit. Check those connections as well.
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
What is replace color cpu toner?
Could the message have been "Replace color PCU (Type A)"? In that case, you need to replace all three color photoconductor units (order Printer Maintenance Kit Type 7100A).
I do not know of any Replace CPU error messages. I hope this helps.
Aug 18, 2010 | Ricoh Aficio CL7100 Printer
How to get borderless printing on a CL7100
Laser printers are unable to print all the way to the edges of the paper because of the excess toner dust that will fall off into the printer unit. The only way to get true full bleed laser prints is to use a larger paper size and then cut the edges off.
Jun 17, 2009 | Ricoh Aficio CL7100 Printer
Ricoh aficio cl7100 doesn't print yellow
does the demo page print ok?
try pushing the yellow developer unit in tight.
May 06, 2009 | Ricoh Aficio CL5000 Laser Printer
Printing red stripe
Replace the magenta photoconductor.
Mar 09, 2009 | Ricoh Aficio CL7100 Printer
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
CL7100 error message sc 440-2 Power off and On.
hello, you problem is a color(cmy) pcu motor lock, the motor is damage or exist a mechanical problem whit the pcu's
Nov 14, 2008 | Ricoh Aficio CL7100 Printer
Color adjust error
problematic machine. transfer belt damaged(white spots ) for temp fix try manual registration from menu
May 09, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL7100
THe oil unit is not entered correctly
Feb 22, 2008 | Ricoh Aficio CL7000 Laser Printer
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL7100 Printer Logo
668 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
