Question about Samsung SCX-4216F All-In-One Laser Printer
Won't print - says 'paper jam 2' but no paper is stuck in machine
We've taken the whole thing apart and there is no paper in the printer anywhere, but it still syas 'paper jam 2' and won't print.
  • smallamelia Feb 22, 2008
    When I took it apart, it looks like the spring has come apart from the paper sensor because the plastichas broken there. Anywhere I could order this part in order to install it myself?
It doesn't print
Posted on May 10, 2008
    Scholar:
  • 41 Answers
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Posted on Feb 22, 2008
  • Maggie B Feb 22, 2008
    I'm guessing you're out of your warranty period?? The thing is, there's no schematic that shows exactly what that part is called and it doesn't appear to be a consumer-orderable part....
    I'd try the phone tech support since they more than likely will have access to better tools to pinpoint the name of that little part.
    The number is: 1800-SAMSUNG (1-800-726-7864) and for printers the hours are 24/7.
    I would get your serial number, etc. from the machine before you call as you may need it for the call.
    Good Luck! (At least you know what the problem is now! : > )
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
Printer has error code H3-30 that wont clear with the #*C* code and will come up with a paper jam error. The last thing that was being done was a 2 side booklet was being printed and the last page...
Check the follwing portions
1.Paper Feed Rollers
2.Drum/assemly unit
3.Fusing Unit.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Sharp Office Equipment & Supplies
The paper in the printer is lined up and everything should be working however I need to print things for work and it tells me that it is either jammed or that I need to load/ reload the paper. I can't...
I have found over the years that printers really don't lie. If it says there is a paper jam there usually is. I have completely taken apart a large laserjet printer to find a very tiny piece of paper causing the problem. Also if you run sticky labels through printers they have a tendency to leave residue or even part of a label behind which will cause the printer to tell you there is a jam. Check your printer very carefully, use some canned air to blow it out. You may need a printer repair person to come out and take it apart to look for possible stuck paper.
Jul 03, 2010 | Canon Pixma iP2600 Photo InkJet Printer
My printer says there is a paper jam, but when I look there is no paper jam. What can i do?
I had a printer that kept giving me a paper jam error. Nothing visually was there though. I then opened up printer, basically took the whole thing apart bit by bit then found a tiny screw loose just laying stuck between print rollers. You can t see this when it was together. It was the work of my 2 year old dropped screw in there. I put together and worked like new. There could be some small object inside near rollers or some where inside your printer. Usually the paper jam means something is jammed in printer. If you dont want to open, which i preffered not to do but i did because i was going to trash my printer, you can call manufacture and see what options they can give you. Some will take it back if you upgrade to another printer, but you will have to pay some extra money.
Aug 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
202 Paper Jam om Lexmark c510
1. Make sure the printer is on.
2. Raise the scanner unit.
3. Remove both print cartridges.
4. Make sure the cartridge carrier lids are closed.
5. Close the scanner unit.
6. Press to turn the printer off.
7. Disconnect the power cord from the wall outlet.
8. Plug the power cord back into the wall outlet.
Jun 09, 2017 | Lexmark C510 Laser Printer
Paper jam
MOST HP PRINTERS HAVE A DOOR ON THE BACK SIDE OF THE PRINTER THAT CAN BE OPENED TO REMOVE A PAPER JAM. HAVE YOU TRIED USING THIS TO CLEAN THE PAPER JAM. THERE MIGHT BE SOMETHING STUCK IN THE PAPER PATH THAT IS CAUSING THE JAMS. CHECK THE WHOLE PAPER PATH FROM THIS REAR ACCESS DOOR. OK?
ARCLIGHT1217
Sep 08, 2008 | HP PSC 1110 All-In-One Thermal Printer
Paper jam
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Roger
Jun 03, 2008 | Lexmark T644 Laser Printer
Error message
hi silv
just seen this post , if still getting trouble with the printer you can try here - PIXMA MP500 -
type in the ? for results.
riz.
Apr 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
412 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
