Philips CDD4851 CD R/RW in my HP Pavillion XT963
When I insert a cd with info. I need to transfer to the computer it will not start.
If I want to make a cd with saved pictures, it will instruct me to;
INSERT A WRITABLE DISC TO CONTINUE
There is no disc in the drive
Please insert a writable CD into the drive D:\.
Even when there is a NEW disc already in it.
How can I fix this error?????? Thanks, Leo
  • 2 more comments
  • caverlt Feb 23, 2008
    Mike,
    The disc is NOT being recognized and therefore will not run.
    Leo
    Mike,
    I followed your instructions and un-installed and re-installed the cd r/rw.
    Didn't seem to make any difference. Still same problem.
    I put in a cd, known to have pictures and the little disc (next to the cursor) flashed a few times but never heard it hummmm as it should and nothing ever came up.
    I have a cd-rom cleaner disc, but it won't play either.
    Being a mechanic, I'm about ready to take it apart and investigate. It may never run again. Ha! Leo
    Hi Mike,
    Found problem with door and disc bed not operating. Looks like some mechanic broke part of the plastic operating rod that activates the thing. Anyway, I have glued it back together and now have to wait 24 hours for the glue to dry.
    Maybe will get to try it out tomorrow.
    I noticed on the reviews of some of the CD/DVD Rom Drives that Tiger Direct sells. It is quite common for my problem with some of the new drives.
    Would you have any preferred brands or do I have to install another Philips? Thanks, Leo
  • mookie2ko Mar 15, 2008
    has lost cd to reinstall and i need it for school
    Genius:
  • 1,019 Answers
if the device is being recognised, As D:- Or E:- et,c.
right click on the device, and select options from there.
such as open/explore et,c.
If the disk has been written to in any way shape or form, even the smallest file. then the disk being read will be classed as empty.
try a different CD Disk, And try re-installing your CD writing software.
Hope this helps mike @ Compurepair.
Posted on Feb 23, 2008
  • Mike Waldron Feb 23, 2008
    ok heres your solution.
    1) go to My Computer.
    2) click on Control Panel.
    3) System.
    4) Click on Hardware then Device Manager.
    5) Then CD/DVD Rom Drives.
    Then if you see your drive there, right click/properties and it will give your drive info ( in the centre Pane ) should read the drive is functioning properly Or similar Or the drive has problems.
    This will also give you options to Troubleshoot the drive.
    6) from here you can also uninstall the drive. ( don,t worry you can do this ) if you uninstall. then click at the top scan for hardware changes, your drive will re-appear as found.
    7) re-boot the computer, and see if this has worked.
    Finally if non of this works, and your drive does not recognise any cd or dvds. ( trying music CD-original DVD et,c ) then your laser-read head is suspect ) You can try a laser-head cleaning disk. or unfortunately drive replacement will be necessary.
    if you continue having problems, don,t hesitate to contact me.
    good-luck Mike @ Compurepair.
    Hey leo,
    thanks for the rating buddy.
    Appreciated.
    If you take it apart.
    Heres how you,ll do it. there should be 4 screws, usually underside or side. the top or bottom panel will lift off.
    Once you,ve got to the laser-hesd. put a small amount of lighter fluid or meths ( anything that will evaporate ) onto a cotton bud ( swab ) gently wipe the bud over the laser eye.
    also you,ll see 2 metal rails, this is what the laser-head slides up and down on. give them a wipe, and put a smear of vaseline on.
    put the drive back together and hopefully Presto. you,ll be up n running again.
    option 2 is to boot up the computer drive connected without lid, and seee if the laser head moves up and down, or a light is coming out of the laser itself. look from an angle not directly into it. it won,t burn you but you can get a bit of a dazzle.
    good-luck buddy. Go-For-It.
    Mike @ compurepair.
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    I have a hp pavillion laptop with the philips dvd-ram sdvd8821
    Just try to reinstall the DVD driver software through the Add Hardware wizard at the control panel. From the Start menu, left click the Control Panel, and the Add Hardware. Right to left click to open. Just follow the instructions and let your PC do the rest. If you have an internet, connect your PC without opening any window. Your PC will autoconnect and search the internet for the proper software driver. Wait for
    a few minutes, until it is installed. Hope this Help.
    Dec 12, 2009 | Acer (KV.16X04.007) DVD Drive
    HP Pavillion laptop won't backup to optical drive...CD/DVD-RW; I do have 1 Click Copy (&Pro) installed as well as DVD43. I have tried to uninstall the DVD43 & 1 Click but it doesn't change...
    HP Pavillion laptops and every others laptops do require CD/DVD recordable for backup not CD/DVD rewritable. Try to use a CD/DVD recordable to see what will happen first.
    Sep 16, 2009 | HP Computers & Internet
    My computerS will burn dvds but won't recognize CDs
    try to insert disk when it in dos mode then normally log in windows
    Aug 16, 2009 | QPS Que! CD-Rewriter CD-RW Burner
    HP Pavillion a712n Desktop PC-CD writable drive space all used up; and it wont recognize blank CD
    have not fixed it. Can you fix the title ? I sokld the pontiac. This is about an HP PC. thanks
    May 28, 2009 | 1989 Pontiac Grand Prix
    Hp pavillion dv9000- cd/dvd rw drive not working
    you have to send it back to hp to get it fixed, this is the second time mine had the same problem
    May 10, 2009 | HP Pavillion DV9060US Notebook
    Can't transfer songs from a cd or my computer
    im going to need a little info first.
    does the computer recognise the disc when u insert it into the comp?
    if it dont u may need to burn the songs onto a diff disc try,
    CD+R
    and
    CD+RW
    if u want to try a rewriteable disc which can be rewriten many times try these,
    CD-R CD-RW
    Mar 02, 2009 | Apple iPod nano
    HP Pavillion dv9000 laptop service tag dv9308nr dvd burner
    vista or xp?
    alot of vista os come pre installed with the software and maybe just a setting you need fixed
    Jul 31, 2008 | HP Pavilion dv9000z Notebook
    Cd burner wont burn whole cd. It burns 6 out of 18 songs and wont work in cd players. hp pavillion laptop dv2000
    Some Cds (or individual songs) are Copyrighted, so they will not burn to new CD.
    Make sure you're using CD. W. and not CD. R.W. as the latter will only play in your computer CD player. Where as the former will play in your car or home player.
    Apr 26, 2008 | Computers & Internet
    Computers & Internet Logo
    572 people viewed this question
    Alun Cox
    David Payne
    David Payne
